![]() | Home > In Car Electronics (L322) > Non Facelift Speaker System Upgrade |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
I suppose I was always going to ask this question, after having my BM54 amp upgraded, but has anyone retrofitted the facelift high end speakers into a non facelift car ?
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 ![]() ![]() |
Mark, did you give it a go and tried to install the newer fl model Harman Kardon speakers to pre rr? |
Wow, this is an old thread. I didn’t in the end. I had the Stage 1 then the Stage 2 amp upgrade from Baris on here and it totally changed the system, even with stock speakers.
The DSP and the logic 7 are different systems, I don’t believe you can simply swap amps. Do the amp upgrade and you will be happy I’m sure. He can also add an Aux in etc if you need one.
