Home > Technical (L405) > Topix
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Topix
Thinking of subscribing to Topix and grateful for any advice on whether it is worth the money? Is it possible to do SOTA and ECU updates etc? My SOTAs have already been enabled but wondered if I had any more control over the car with Topix? i.e. can I activate updates etc. 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #546159 6th Mar 2020 8:34am
dont think you can...
try the 'my landrover' app, that might..
https://www.landrover.co.uk/ownership/my-land-rover.html ... - .- -.
Post #546186 6th Mar 2020 11:10am
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
The "Independent operator" level login on Topix does not enable access to enable SOTA. It does allow you to use the Pathfinder software for diagnostics but not change vehicle configuration in the way you can with earlier vehicles and an IIDTool, for full functionality you would also need to acquire a Diagnostics over IP interface. You do get access to the on-line workshop manual, wiring diagrams and all the applicable service bulletins.
Whether it's worth paying for is up to you. There are several options for the subscription duration from 1 hour to 1 year.[/i]
Post #546236 6th Mar 2020 8:44pm
