Home > Wheels & Tyres > 275/50/20 Tyres on 20" Stormer Wheels
Iain24ace
United Kingdom 2007 Range Rover Vogue SE TDV8 Barolo Black
Afternoon folks,
My 2006 L322 Vogue SE came fitted with RRS 20" Stormer Wheels and 275/40/20 tyres which seem to crash alot and give a hard ride. Has anyone fitted 275/50/20 tyres to these wheels to improve the ride and did they fit ok?
Cheers Iain.
Post #546093 5th Mar 2020 3:57pm
https://www.fullfatrr.com/forum/topic9596.html
Post #546099 5th Mar 2020 4:35pm
gettingold
I’m sure I’ve read the RRS guys put 275/45/20 on theirs with positive feedback.
https://www.rrsport.co.uk/forum/topic39605.html?highlight=275 visiting from www.rrsport.co.uk
Post #546104 5th Mar 2020 5:12pm
Vogue
Many years ago - back around 2008, somebody (an Australian ?) fitted 285/50/20’s AT Tyres to his L322, I am sure they fitted ok - a search may yield results.
If the 285’s fitted ok then the 275/50/20 should be ok.
275/45/20 will definitely fit as they are almost the same diameter as the oem 255/50/20’s - and I have fitted several sets to my 322’s in the past. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #546392 8th Mar 2020 7:35am
Bluegreygreen Rangie 2
Australia
Ive run 275/55/20 for over half a decade ... imo they are the perfect tire size for the car , Youll need to heat up and push in the rear inner guard a little where it is mouled over the fuel filler hose and the front can very seldom rub on the front of the inner guard but it's no dramas at all
You also get better rim protection from the slightly wider rubber and about 80rpm dropped off your engine speed which is good, particully on the freeway in 6th gear
If your after the best ride make sure to get a p (passenger) rated tire not a light truck rated tire... i run 36psi front and rear and find it to be very good with no wear issues etc
Dave 2010 3.6TDV8 Autobiography
Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #546404 8th Mar 2020 8:35am
gha
Norway 2007 Range Rover Vogue TDV8 Santorini Black
275/50/20 is a great combination. No mods required.
Post #571132 28th Oct 2020 12:32pm
