Home > Technical (L322) > Gearbox fault after shop disconnected battery
jarrettstone
United States 2011 Range Rover HSE 5.0 V8 Santorini Black
I have an intermittent gearbox fault. It has started after a repair shop disconnected the battery to replace a coolant line under the intake. I believe the TCM needs to be reflashed and I’d like to know if this can be done with the IID TOOL. The repair shop it was in doesn’t have the capabilities to do the reflash.
The fault/limp mode goes away after restarting the car.
Post #545845 3rd Mar 2020 3:53am
welcome to the forum..
before you spend out any money try this,
disconnect the battery , the correct procedure is in the wiki.
after you have re-connected, turn the steering wheel fully left and then fully right..this sometimes elevates the hdc error.. ... - .- -.
Post #545850 3rd Mar 2020 7:33am
jarrettstone
I am not getting an HDC error, does this matter?
Post #545884 3rd Mar 2020 12:36pm
sorry i meant just the 'error' ... - .- -.
Post #545885 3rd Mar 2020 12:53pm
