Home > Technical (L322) > No Airbag in Driver's Door
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
Hi All,
New to the forum, which I have found to be immensely informative.
Just bought a 2012 L322 4.4 TDV8 Vogue SE with 86k miles as a replacement for my 2010 3.6 TDV8. This is my 5th Range Rover, so am generally capable of sorting out the niggles associated with Range Rovers.
Overall fantastic vehicle as proven during a 2,000 mile trip during the first week of ownership.
The driver's door would not open from the outside yesterday morning. No problem I thought, cable broken - removed driver's door card expecting to see the driver's door airbag - not there. No screw holes through the form door card backing where the airbag should have been fitted - it appears therefore that there never was a drivers door airbag fitted from new.
Has anyone else with a 2012 L322 4.4 TDV8 Vogue SE noticed that there is no airbag in their driver's door?
Post #545784 2nd Mar 2020 1:32pm
didnt think there was an airbag in the door...looked at the WM and couldnt see it....
is it not in the 'B' pillar..? ... - .- -.
Post #545787 2nd Mar 2020 1:53pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I was under the impression that the side impact airbags are in the side of the front seats?
Jim
Post #545788 2nd Mar 2020 2:00pm
this is from the owners manual,
Post #545791 2nd Mar 2020 2:25pm
4434Morrison
Thanks for Responses
Thanks for your responses.
I had been expecting to find an airbag module on the inside if the driver's door, as all posts on this forum and others, relating to the drivers door lock mechanism refer to removal of the driver's door airbag module.
Still, we live and learn....
Thanks again! 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #545794 2nd Mar 2020 2:33pm
kimlahti
Finland 2008 Range Rover Vogue TDV8 Alaska White
I guess it was moved from door to seat when dashboard was facelifted. -08 3.6 Vogue
-87 951
Post #545852 3rd Mar 2020 7:51am
RobErica
Netherlands
Bump this, can confirm. I found out yesterday that my 2007 tdv8 doesnt have an airbag on the right side. Left i dont know. No wiring for as far as i could see, so think its factory i guess.
Post #682382 11th Jan 2024 7:07am
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
It was only the first gen L322s that had airbags in the doors when they used the BMW style seats when the first face lift was done around 06 was it and the front end changed the seats changed also and that from memory is when the side air bags moved from the door to the seat.
Post #682477 12th Jan 2024 7:16am
