![]() | Home > Technical (L405) > Restricted Performance on cold starts MY15 SDV8 |
Clutching at straws as never had a cold start prob but it sounds like fuel issue. Poss filter or fuel starvation? Check hi pressure fuel lines fitting ok. |
EdinburghRR Member Since: 02 Mar 2020 Location: Edinburgh Posts: 3 ![]() ![]() ![]() |
Thanks for the input Dolphinboy. Car was dropped off with Stratstone thismoring so hopefully I will have an answer and update today. I have bought a OBD2 reader as I feel I might need it in the future |
Stratstone tech says exhaust temperature censor has gone and needs replaced. No part in until tomorrow of course but hopefully a fix!
thanks for the info.
roel2018 Member Since: 01 Oct 2018 Location: Aalter Posts: 39 ![]() ![]() ![]() |
It seems that I had the same issue last night with almost the same engine (L322 TDV8 4.4.). iCarsoft is telling me some weird values and it seems that also my exhaust gas temperature -bank 2 - sensor 2 gives a failure. No degrees! So this could give error P050E Restricted performance cold start... |
