Home > Technical (L322) > Battery compatability
Leesbay
England 2011 Range Rover SE TDV8 Zambezi Silver
Anyone using an Exide EK950 agm 850cca 95ah battery on their 4.4 tdv8 2010-12?
Specs look right/dimensions same as oem, just want reassurance before pulling the trigger as Tanya have them circa £100 currently
Thanks in advance
Post #545397 27th Feb 2020 11:28pm
GGDR
That one you mention is an 017 however I believe you need an 019
Some people sqeeze an 020 but it's v.tight.
. Cheers, Greg
Post #545398 27th Feb 2020 11:31pm
GGDR
Interestingly the 017 you mention is
017: Capacity 95 Ah & CCA 850 A
vs
019 Bosch is also 95 Ah & CCA 850 A
So I'm not sure with the 000 number system means...
Somebody should come along here soon and explain....
.. Cheers, Greg
Post #545400 27th Feb 2020 11:36pm
Leesbay
Yes that fact confuses me too
Same spec and size etc and some even list it as an 017/019
Dont know whether it makes any odds tbh as specs are identical but would be nice to get a definitive answer
Ive emailed Tanya and hopefully will get a reply tomorrow
Post #545401 27th Feb 2020 11:39pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Exide is the go to battery for Maserati owners. They are VERY sensitive to low voltage and most owners have them on trickle chargers. I will be buying one of these once you have the 017/019 answer as my LR battery is failing. 2011 4.4tdv8 Vogue
Baltic Blue
Post #545403 27th Feb 2020 11:50pm
Leesbay
Will post back with answer asap
I had one in my last touareg 3.0tdi v6 and it never let me down so happy to use same again in the temperamental Tdv8 if its compatible
Post #545404 27th Feb 2020 11:54pm
jordon0
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
run an ek950 on my tdv8
fits fine exactly the same size as the genuine battery i took off
no more alerts of low battery system shutting down
did tell car new battery was fitted so it knows how to charge it
Post #545412 28th Feb 2020 9:07am
Leesbay
Tanya confirm its a match
Just paid £107 with discount code PAID20 free delivery👍
Post #545428 28th Feb 2020 11:46am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
My experience, and there is a thread somewhere -- specifically for 4.4 TDV8 is it needs to be - 019 (not 020) and AGM -- get those two things and it's then simply a choice of manufacturer, which I accept is a different kettle of fish Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #545431 28th Feb 2020 11:58am
Gazcw
Strange. That code does not work and total cost is 134.78 2011 4.4tdv8 Vogue
Baltic Blue
Post #545434 28th Feb 2020 12:14pm
Gazcw
Ah it is via ebay and not their website.Do you buy it now and add the code via paypal? 2011 4.4tdv8 Vogue
Baltic Blue
Post #545437 28th Feb 2020 12:19pm
Bluegreygreen Rangie 2
Australia
Northstar
Guys if you want to fit a real battery to your car forget all of the above, Fit either and only a Northstar or Odyssey (both companies have one model which fits and exceeds all other options.. Ive done all the research for you beleive me
The batteries are built to military standards and unlike all other crap on the market are made from pure new 100% virgin lead not recycled garbage which is not a true 100% lead battery, Northsar have 4 or 5 year warranties (country dependent) which should give you some idea of what you are purchasing .. they are not cheap nor do they make one the "correct size" for the L322 but imo they in retrofitting reality make a better sized battery as they are not longer but have more height in their build and in the L322 we have plenty of height to play with , I will get a post up in a day or so on fitting mine with pictures.... i had to re configure the positive battery terminal which was a very simple task and instead of making up new brackets i have two heavy duty ratchet straps holding the battery in place .. yes it might sound dodgy however it is probably far more secure than factory fitment in all honesty
This is the battery i fitted to my car which is rated , 1370 CCA , 103Ah reserve capacity which is a bit of a funny measurement pending on battery manufacturer, and i have a five year warranty
https://www.northstarbattery.com/product/nsb-agm31m
I got sick of having to worry about battery drain in remote areas etc and we can't clutch start our cars been automatic , we have huge amounts of current drain as you all know so i wanted to sort the problem once and for all.. I have had this battery in for over two years... it has been flawless so far.. spend the coin fit a real battery with 100% pure lead and be done with it!!
There is a very good reason why this battery is 35 kilos!, You will find that it is almost double , yes double the weight of what you are looking at above.. why?, because its double the battery
Dave 2010 3.6TDV8 Autobiography
D4 Bullbar, Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 255/60/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #545462 28th Feb 2020 4:00pm
Australia
Odyssey equivilent below
https://www.odysseybattery.com/Batteries/Model_31PC2150T
And i have to say... wait till you try to lift one of these things into the L322 engine bay... you just about need a crane and im not kidding
GAP Diagnostics
Post #545465 28th Feb 2020 4:05pm
Leesbay
Gazcw
If you add to ebay basket then go to checkout just add the code PAID20 and itll take the 20% off before you proceed to making payment👍
Post #545477 28th Feb 2020 5:32pm
Leesbay
Im sure the Odyssey is a cracking battery but for us UK owners it appears that the battery posts are different and the fact we need to ‘fettle’ would certainly invalidate any warranty
Fir £107 and a 4 year warranty from a reputable UK company with an easy return policy i think im more than happy tbh👍
Post #545479 28th Feb 2020 5:37pm
