![]() | Home > My Range Rover > BD L322 Triple Black Autobiography Supercharged |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
Looks good.
362bkr Member Since: 15 Oct 2014 Location: Devon Posts: 679 ![]() ![]() ![]() |
And it’s a yes from me ! Very nice 👍 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
You are going to have to "murder" all the lights as well |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Thanks, chaps.
Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132 ![]() ![]() ![]() |
BD
Thank you both.
David405 Member Since: 17 Feb 2020 Location: Cheshire Posts: 37 ![]() ![]() ![]() |
Nice L322, I think they look great in dark colours, mine was very dark blue 2013 405 TDV6 Vogue SE Barolo Black
Well that is nearly my first week in Range Rover ownership over. Definitely have learned to appreciate the character of the car a little.
Just had mine over a week now, and bingo for my first warning light come on 😂 Just as I booked it in for a gearbox and supercharge oils change. On my way home; was in S and pushing it a bit the coolant low warning came in 😬
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Check the coolant while the engine is cold - in particular look at the bottom of the expansion tank as the connection there can slip and drip a tiny amount. Might need pushing in a tad.
Thank you 🙏
Yes you can see the water pump - front right of the engine as you stand at the grill but it's quite low down so get a torch and have a good look. Any signs of pink/red gunk and you have a leak. If its on it's original pump it may well the that.
Thanks very useful |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
Thanks for all this info fellow 5.0sc owner here, had the 4.2sc before and now seeing jus how many differences there are and have come to the conclusion its a revolution and not and evolution in engine terms.
