Home > Technical (L405) > white smoke from exhaust on start up |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
I’d defo get it looked at for piece of mind
20th Feb 2020 5:53pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3752 |
A bit of white smoke on start up is normal - all mine have previously done this and it is merely condensation evaporating from a cold engine until it warms up.
20th Feb 2020 6:17pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8620 |
is it from the exhaust of from under the car?
20th Feb 2020 6:37pm |
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 486 |
Thanks guys, definitely from exhaust pipes and so strong that it gets in to the cabin. I can only describe it as puffing white smoke...no changes in coolant or oil, 63k miles travelled. Service 1k miles ago. 2017 Range Rover Vogue V6 Diesel
20th Feb 2020 7:00pm |
http://www.fullfatrr.com/gallery/albums/us...ke%202.mov
21st Feb 2020 9:23am |
I was wondering if it was failing glow plugs but I'm guessing the rather sensitive ECU electronics would spot that one? 2017 Range Rover Vogue V6 Diesel
21st Feb 2020 10:03am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35374 |
mines a 16MY tdv6 and i havnt used mine since yesterday morning..went out 5 mins ago,started it and no smoke like yours.
21st Feb 2020 11:09am |
That’s an interesting point re: the adblue Stan.. might check that. What gave you that idea? 2017 Range Rover Vogue V6 Diesel
21st Feb 2020 11:40am |
its only a theory ..the ad-blue is mixed with the exhaust gases and my thought is that if its low then he exhaust gases come out un-treated.. ... - .- -.
21st Feb 2020 11:50am |
I hope it is something as simple as that. I don't have any adblue top up warnings at the moment but I'll try topping it up anyway to see if it makes any difference. 2017 Range Rover Vogue V6 Diesel
21st Feb 2020 12:00pm |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1233 |
I thought the car will not start if low/out on ad blue. ....but what do I know? Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
22nd Feb 2020 11:06am |
I thought so too. Topped it up anyway and will see what happens.. 2017 Range Rover Vogue V6 Diesel
23rd Feb 2020 12:50pm |
