![]() | Home > Technical (L322) > Ambient Air Temperature Sensor |
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132 ![]() ![]() ![]() |
Thanks that is exactly where I thought it was but definately not there on my car so need to go searching for the cable/sensor as it must have dropped off. Current cars
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
Has the display only recently started showing -40?
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 99 ![]() ![]() ![]() |
I was under the impression that the sensor was in the drivers door mirror housing..?? |
I only got the car last wednesday and am starting to find and sort all the little things that need done. I would guess that it has been like that for a while. Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
On my 2003 car, it was clipped to the rear of the front grille, so to take the grille off, you had to physically unmount the temp sender.
I think that's only on 2010 cars and later. Mike |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
Hi, just bumping this old thread as my reported external temp is around 10 degrees down, i.e. on a normal day 12' I get the ice warning and 2' showing.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Number 7 on the left hand mirror only.
That's great, many thanks, I was expecting it to look something like the original, tiny, no wonder I couldn't find it.
