![]() | Home > Maintenance & Mods (L405) > Mudflaps - To fit or not to fit |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1403 ![]() ![]() ![]() |
I've had them on all of my RRs. Dealer fitted. The car still gets dirty, but I expect less so, they are also useful in reducing the amount thrown at anything being towed, or vehicles following when in convoy off road, perhaps also stones at the sides of the car and maybe also cars behind on poor road surfaces, especially with blockier tread tyres. Aesthetics inferior to function here. Only Range Rovers since 1988 |
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 ![]() ![]() ![]() |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
Why not just buy the flap material online and cut it how you want, rally style dragging 2mm off the floor and sticking out of the arch |
Just read this thread.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3787 ![]() ![]() |
I had flaps fitted on my previous RR and immediately regretted it - they totally ruined the look of the vehicle and alas it was too late to go back due to mounting holes being drilled. Plus it’s very easy to get them ripped off when off-road, which then also results in panel damage.
322, holes were drilled by the MD into the rear bumper and also the panels in front of the doors. When I bought the 405 the MD asked if I wanted flaps and also mentioned that they also had to drill holes in the panels like the 322 - I didn’t ask which panels though as I had ruled them out - permanently! 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Removing the front mudflaps from our L405 would leave screw holes as per the below images (don’t think that would cost too much to make good tbh).
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
I might get me a rear set for the new shiney. On the red 322 not having them resulted in us decorating the front of the caravan in mud and road film every time we went anywhere!! There is nothing that can't be fixed with a hammer😜😜
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
I don't have them on my 405 Ryan... I made sure when i facelift it NOT to buy a rear bumper with mudflap holes! I had all the undersides PPF'd and that keeps chips to a minimum ![]() |
2010BlackL322 Member Since: 30 Oct 2021 Location: London Posts: 119 ![]() ![]() ![]() |
Agreed. I’m taking mine off, front and back, bought a second hand pair of lower wing plastic panels, will get them sprayed up. On the rear, there is just one hole on the bumper, I have bought a set of plastic bungs, 10mm and will insert them. Doubt anyone will notice. The mudflaps don’t seem to do anything, see pictures
https://youtu.be/UHBbLWZXw4A |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 150 ![]() ![]() ![]() |
I fitted genuine mud flaps to my car yesterday. The RR instructions leave a lot to be desired. First up, there is no need to remove the road wheels, there is plenty of room to get them fitted with the car at the max height setting.
Just removed mine, dirt and rust trap, had rusted the fixings and brackets. Took a grinder to get the bolts off, they were soaked in dirt and grime where they attach to the lower bumper cover, no amount of power washing would get to them hidden away. Plugged the holes with some plastic bungs.
