Home > Technical (L322) > Gearbox ?
mudknight
2003 Range Rover Vogue Td6 Java Black
Gearbox ?
Hello all, on the way home tonight my 2003 l322 td6 started vibration then a whining sound , it's only stopping in one gear , not changing up or down . I've tried it in manual and it's the same but indicating different gears although not changing gear.
Help needed . I've plugged in my new icarsoft diagnostic tool but nothing comes up.
Post #544334 18th Feb 2020 7:52pm
ebajema
Mmmmmm it sounds like the dreaded GM box has failed. If it is the original box still, than it sounds like it lasted very long. MY 2010 5.0 SC Galway green and sand interior!!
Post #544393 19th Feb 2020 10:38am
mudknight
The car has done a little over 200,000 miles , had the gearbox rebuilt at 145,000 miles , maybe they didn't do a good enough job ?
Post #544411 19th Feb 2020 1:24pm
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
The GM 5L40-E Automatic Transmission: Common Problems
https://axleaddict.com/auto-repair/The-GM-...n-Problems
Post #544418 19th Feb 2020 3:00pm
