![]() | Home > Technical (L322) > Restricted Performance |
jc132jc Member Since: 05 Nov 2019 Location: Suffolk Posts: 32 ![]() ![]() |
Sorry forgot to add it’s a 2012 V8 Westminster |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
It’s nearly always a boost leak, even though you’ve had a smoke test, you really need a good eyeball + white tissue check around every hose and union starting with the four donut hoses. You’re looking for soot escaping which the tissue will show. If you can get a high pressure smoke test it may show up but the low pressure just can’t pressurise the system enough. Search ‘donut hoses’ + ‘restricted’ - common issue but thankfully (hopefully) usually a simple fix. On mine for example a circlip gave up. Bent the clip, cleared the code and sorted.
Thanks GGRD, would a boost leak cause high soot levels in the DPF ?
Yes definitely. These intake leaks will create too much soot and fill your DPF
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
Number one fault in my 4.4 tdV8 fault log.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
When you got home, how did you clean the dpf? BMW i3 Electric Car
AJGalaxy2012, I got a local DPF specialist to come and do it. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
As above, get a high pressure leak test done.
Dr Rob, I do indeed still have the original rubbish donuts on there so I will change them all while it’s off the road.
There are a lot of snake oil DPF fixers out there, in my opinion and experience you need the DPF off the car and in a machine like a "flash" machine. That's how they do commercial DPFs, London busses for example. But for now I would focus on finding the boost leak. The DPF may be ok and if you get into a cycle of normal use should settle down. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Ah OK, it seems that the sensors are reporting a high pressure differential which means either a) one or both sensors are faulty or b) the DPF is again blocked. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
What's it reading?
Head over to:
GGDR, I will have to check but I have the yellow DPF warning came on again |
