![]() | Home > Technical (L405) > Land Rover Removable Hitch Problem |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Never heard of that one - the R clips are usually very strong & wouldn’t vibrate off - I’d be suspecting some sort of foul play.
mattprice693 Member Since: 27 Jan 2019 Location: Brecon Posts: 16 ![]() ![]() |
Thanks for that. Just ordered it off eBay. I can’t for the life of me think how those pins have come out because they usually need a firm grip and and a good pull to remove😮. There is a very small amount of play of the hitch within the receptacle which depending on the road surface sometimes makes a clonking type noise. Whether this exerts enough lateral force into the pin and in turn the R Clip is beyond me. I can’t believe someone would remove it, but who knows? |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 475 ![]() ![]() ![]() |
Thats very worrying, but have to agree with Alistair, I have used these for many years on commercial vehicles and never known one come out, the lock sounds a good idea. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Absolutely... These are used in both my mini digger and my ride on mower and in 10yrs plus hard labour, ive never lost one! |
If the vibration bothers you - then Red Merle found a solution -
Thanks for that link too. Just found that mine is fitted with an anti rattle bolt. Will have to give that a try when we’re out next. |
