Home > Maintenance & Mods (L405) > Prev owner extended period driving locked rear diff. Issue? |
Felstmiester Member Since: 06 Apr 2019 Location: Hertfordshire Posts: 262 |
In short. Yes! I would set it hasn’t done it any favours. I’m certainly not an expert and maybe the newer 4x4’s like the l405 have some kind of fail safe? But having the diff locked on tarmac wouldn’t be good for the diff at all. If the wheels can’t spin freely like on mud or snow then it will put strain on diff. |
10th Feb 2020 2:59pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
That's what I was thinking. Would this cause issues with the tranny too...or just the rear diff?
10th Feb 2020 3:20pm |
I wouldn’t of thought the diff needed to be locked to diagnose pinion seal. I knew a fella had a l322 and somehow that got put into diff lock and it done so much damage it wrote the car off. This was way back before the l405 was even out |
10th Feb 2020 4:01pm |
lol...well hopefully and I think I'm ok since the car is driving....I'll need to get the rear diff addressed though. 2014 FF Autobiography 5.0 SC
10th Feb 2020 4:08pm |
Is there not a constant light on the dash when in diff lock? I know on the older defenders they had no light initially but the light came up after being driven on a hard surface after a few miles because it whines the diff up ( obviously depending on how many turns uve done) you then had to drive it in reverse until the light went out. I would have thought the newer Land Rover/ Range Rover has some kind of warning light??
10th Feb 2020 4:31pm |
I have no idea what the light would look like, the L405 is so new to me. No check engine light or anything. I just saw on the nav display the lock symbol on the rear.
10th Feb 2020 4:46pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
I didn’t think you could manually lock the diffs....... |
10th Feb 2020 5:19pm |
I have a 2014 Autobiography. It shows on the Nav. You can select them lock/unlock. 2014 FF Autobiography 5.0 SC
10th Feb 2020 5:40pm |
Yes I’m sure you can manually lock the diffs. But surly there must be a massive annoying warning light letting you know it’s locked ? |
10th Feb 2020 6:01pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35291 |
i thought the diff lock was electronically controlled and was activated when needed.. ... - .- -.
10th Feb 2020 6:39pm |
This is the menu option on the NAV that I'm talking about where you can lock/unlock.
10th Feb 2020 6:54pm |
Not fitted to all cars though. Some have none, some just the rear and rarely front and rear. Think even when not fitted it still shows on the screen as an open lock but just can’t be switched on. |
10th Feb 2020 7:03pm |
So yea....the bottom (rear) was set to lock for who knows how long. And I did notice the rear diff leak which LR advised to replace pinion and seal. Just trying to correlate the two.
10th Feb 2020 7:12pm |
Just my assumption. I would of thought if the diff was damaged at this moment it would be noisy or you would be feeling some kind of vibration. Please don’t quote me on this. It’s normal for a pinion seal to go anytime. Not 100% having diff lock on would cause it. |
10th Feb 2020 7:26pm |
