Home > Technical (L322) > Alarm went off in high winds
Simmoto
United Kingdom 2010 Range Rover Vogue TDV8 Rimini Red
The alarm on my FF went off last night in the wee hours, could it be the gales we are having in Scotland? Was certainly stormy last night. Did a search, it looks like the bonnet sensor is often the culprit?
I pressed the button only once when I last locked it before leaving home 4 days ago. Is this single locked with the internal sensor not activated?
I was fine, I'm away from home but the Mrs had some choice words and was none too impressed Shocked
Cheers
Simmo
Post #543386 8th Feb 2020 6:14am
p38arover
Australia
Airflow into the cabin setting off the interior sensor? Happens with my L322 when the camping fridge switches on and it's fans start. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #543387 8th Feb 2020 6:20am
Simmoto
Thanks, sounds like it could be, how would you stop that? Put it on cabin recirc?
Cheers
Post #543388 8th Feb 2020 6:28am
p38arover
Australia
In my case, it requires an extra press of the lock button to disable the internal sensor. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #543389 8th Feb 2020 6:36am
Simmoto
I thought on my 2010 L322 one press was perimiter alarm and two presses was perimiter and interior alarm? Only just got it though so not sure, can anyone confirm as I don't have access to the owners manual right now?
I left the car locked with one press only so leads me to think it's the bonnet sensor - bonnet gets lifted in high winds and alarm goes off?
Thanks Very Happy
Post #543408 8th Feb 2020 12:21pm
link to the owners manual is in the wiki.. ... - .- -.
Post #543409 8th Feb 2020 12:23pm
Simmoto
Thanks Stan, found it.
From the handbook, below. Single locking (one press of the button) doesn't switch on the alarm inside the car
Press the lock button on the Smart Key briefly,
to single lock the vehicle and activate the
perimeter alarm. The hazard warning lamps
will flash to confirm. A second press within
three seconds will double lock the vehicle and
activate the full alarm system. The hazard
warning lamps will flash a second time to
confirm the enhanced lock/alarm state.
SINGLE LOCKING AND PERIMETER
ALARM
Single locking secures the vehicle and prevents
the doors and fuel flap from being opened from
outside. The doors may still be unlocked and
opened from inside the vehicle. In this state,
only the perimeter alarm is activated. The
perimeter alarm will sound if:
• The bonnet, tailgate or a door are opened.
• The vehicle battery is disconnected.
• An attempt is made to disconnect the alarm
siren.
Note: This setting should be used in
circumstances such as travelling on a ferry,
when pets are to be left in the vehicle, or if a
window must be left open etc.
DOUBLE LOCKING AND FULL ALARM
Never double lock the vehicle with
people, children, or pets inside. In the
event of an emergency they would be
unable to escape and the emergency
services would be unable to release
them quickly.
Double locking secures the vehicle and
prevents the doors being opened from inside
or outside of the vehicle. The doors cannot be
unlocked or opened from inside the vehicle
when double locked.
This provides additional security if the vehicle
is left unattended. The vehicle cannot be
opened by breaking a window and operating
the door locks from inside.
Additionally, double locking also activates the
full alarm system. Once activated the alarm
system will sound if:
• Movement is detected within the vehicle
interior.
• A window, front or rear windscreen or
sunroof glass are broken.
• The vehicle is raised or tilted.
system.
Note: In this state, an open window or sunroof
will cause the alarm to sound due to the
movement of air currents. For this reason,
ensure all windows and the sunroof are fully
closed before double locking the vehicle.
Post #543411 8th Feb 2020 12:46pm
mjdronfield
I think the locking procedure swapped round at some point. My TD6 was opposite with the button presses.....
As already mentioned....bonnet switch could be the culprit also.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #543414 8th Feb 2020 1:14pm
Simmoto
Thanks, yeah so I think P38Rover's 2004 L322 is the opposite of late cars, my 2010 is a very late 3.6 so I'm not sure? I suppose I could get the wife to put the guinea pig inside and then experiment Very Happy
Post #543415 8th Feb 2020 1:52pm
mjdronfield
Or you could leave a window down and just stick your hand in......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #543420 8th Feb 2020 3:35pm
Simmoto
Well yeah but there'd be no drama in that Laughing Mrs S is not keen to lock it again so i'll need to take a look when I'm home...
Post #543424 8th Feb 2020 4:31pm
p38arover
Australia
Yep, looks like the procedure has been reversed. Maybe the earlier procedure was a carry over from BMW. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #543444 9th Feb 2020 12:30am
