![]() | Home > In Car Electronics (L405) > TV sound out of sync L405 |
Felstmiester Member Since: 06 Apr 2019 Location: Hertfordshire Posts: 262 ![]() ![]() ![]() |
Have you had a software update? This should sort the problem your having |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
Freeview / dtv can very easily get out of sync with any TV or set top box and a re boot from no power usually sorts it out . However disconnecting the battery gets messy with the trackers etc . Just change the country in the setup menu of the TV to another out of EU country , then switch the radio on & off and then set it back to the UK and allow it to re tune . Hope this helps . |
Heyloft Member Since: 28 Apr 2012 Location: UK Posts: 64 ![]() ![]() |
Thank you for the tips.
Software up to date and nowhere to change the country in setup 🤷🏼♂️
Settings / Change / select other country / switch off then on / Revert to UK and allow it to retune .
Different GUI in the L405 2019
I was wondering about the age of your car , but there must be a way to change it ? suppose you drove to any Mainland EU country its unlikely to be able to change on its own -- or can it ?
I agree Charlie, but nothing in manual or on Topix.
Any fix for this ? |
I’ll let you know after a visit to the dealer on Wednesday 💁🏼♂️ Wot's that in old money |
Well they said they updated the firmware on the infotainment module.
Hmmm it might just be how it is , out of sync sound to picture is surprisingly common on TV & recorders . |
