Home > Technical (L322) > Strap / strut bolt
ebajema
Strap / strut bolt
Hi, does anyone know where I can buy the bolt that goes through the top of the driver side tailgate strap and also has the little ball for the top end of the damper strut??? I have a new set of straps but with 4 normal bolts. The old bolt is in the solidly rusted top of the old strap with very little chance of ever coming out. MY 2010 5.0 SC Galway green and sand interior!!
Post #542952 4th Feb 2020 8:44am
Weegie
Eugene, you will have to check the thread but - https://www.amazon.co.uk/Threads-Strut-Bol...B07WDP2452
Not NZ but would probably send.
Or more locally to you - https://www.nzpartsonline.co.nz/hardware/g...-fittings/ John
GAP iiD BT
Post #542967 4th Feb 2020 10:27am
ebajema
Brilliant, thank you very much !!! MY 2010 5.0 SC Galway green and sand interior!!
Post #543073 5th Feb 2020 9:28am
ebajema
The brute force approach actually did work. Nut splitter to get the badly corroded head of the strap apart, clean up the threads with file and wire brush and it is back in the car. Properly covered in Rhodina II, best grease for this type of application IMHO. MY 2010 5.0 SC Galway green and sand interior!!
Post #543637 11th Feb 2020 9:27am
