Home > Technical (L322) > Wing Mirrors
Springer
United Kingdom 2003 Range Rover Vogue Td6 Galway Green
Wing Mirrors
Hi the lights in my Wing Mirrors have stopped working have had them apart and changed the lamps but still no joy has anyone any ideas
Thanks
Peter
Post #542657 1st Feb 2020 3:29pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Did you replace with normal 501 capless or go led ?
Post #542690 1st Feb 2020 8:09pm
Springer
Tried both and neither work
Post #542710 1st Feb 2020 10:40pm
RaveRover
Australia 2005 Range Rover HSE 4.4 V8 Java Black
Are you able to move the mirror up, down etc with the toggle switch? Or the passenger mirror wont tilt downwards when reversing? what I had to do was, with the ignition off, pull the appropriate fuses, turn the ignition on for about 10 secs, turn it off, refit the fuses and turn on the ignition again. this resets it and it'll usually work again.. Hopefully the side lights are apart of this system and works for you. Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
1986 RRC Highline with offroad mods. Arctic Silver
2001 P38 HSE. Ardeness Green.
1995 RRC soft dash (beautiful car) Green.
2005 L322 HSE V8. - Current, most awesome car yet. And most expensive.
Post #542726 2nd Feb 2020 5:48am
Springer
Mirrors move as they should but will try pulling the fuses
Post #542735 2nd Feb 2020 9:02am
The mirror lamps time out really quickly and are voltage sensitive! So will only work on normal bulbs and needs 2 to be working! On my old cars i used to rewire the mirror lights to the plug at the bottom of the door. This meant i could run LED bulbs and they wouldn't time out! Therefore working as i wanted/expected from day one! Thumbs Up
Post #542757 2nd Feb 2020 11:27am
rjff
May seem a silly quesion, but have you turned off the interior lights?
On mine if I do that the approach and puddle lamps don't illuminate. Cheers
Richard
Gap IIDBT
Post #542768 2nd Feb 2020 12:55pm
Springer
Put back in two good ordinary lamps did the fuses all interior lights working as they should but still no wing mirror lights are they only supposed to come on when you unlock using the fob ?
Post #542785 2nd Feb 2020 3:48pm
rjff
They do on mine. I can't say on your model I'm afraid.
Sorry I can't be of more help. Sad Cheers
Richard
Gap IIDBT
Post #542795 2nd Feb 2020 6:02pm
Springer
Got lights working don't ask me how and also work with canbus free led's Very Happy
Post #543217 6th Feb 2020 1:50pm
rjff
Thumbs Up Cheers
Richard
Gap IIDBT
Post #543231 6th Feb 2020 3:47pm
