Home > Technical (L322) > L322 Continuous Beep at motorway speeds |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1254 |
Its not a speed warning is it? |
29th Jan 2020 11:08am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 815 |
no, the beeps carried on while I slowed down to 50mph, and still carried on till I came to a stop
29th Jan 2020 11:15am |
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 |
Sounds like the hidden JLR AI function that assesses your driving ability and recommends a safe speed "Gloria" 2002 L322 Voguish V8 LPG - carcass
29th Jan 2020 12:16pm |
maybe maybe - but even when slowing down to 20mph, then to 10mpg and to a stop, it was continuosly beeping till I turned the engine off - any ideas folks |
29th Jan 2020 9:06pm |
Have you got any IIDTool or equivalent to run some live value tests ideally, or just read faults, clear faults, read faults etc? "Gloria" 2002 L322 Voguish V8 LPG - carcass
29th Jan 2020 9:52pm |
my mechanic put his Snap On Verus on the car back on the 16th Jan, but no faults came up
29th Jan 2020 10:14pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 677 |
Does your car have lpg fitted by any chance?
30th Jan 2020 12:08am |
yes you are right
30th Jan 2020 12:32am |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 |
I ran an X5 with lpg and the tank level indicator was also the switchover if you wanted just petrol. It will switchover under hard acceleration if there is not enough pressure to get the gas into the injectors quick enough I believe. Was it nearly empty? |
30th Jan 2020 8:07am |
yes it was fairly low, the indicator showing 10 to 20% left in the tank I reckon, I will fill her up today, and when I go back home give it a blast and see if the beeping comes back on again - hopefully it is nothing more sinister than this |
30th Jan 2020 11:00am |
Is it a relatively new install? Injectors may be undersized for the engine size but I reckon it was levels that were issue.
30th Jan 2020 11:03am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3162 |
Well spotted Mariana. Think you may well be right. They do ping when low or switching to petrol, especially under acceleration.
30th Jan 2020 11:33am |
