Home > Technical (L322) > EAS fault - pressure drops when filling
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
I'm getting an occasional fault that triggers the dreaded dash error message and bong.
This happens a couple of times in quick succession, then might go a week with nothing after clearing the single fault code of ' pressure drops when filling'.
The car doesn't seem to lose any pressure or lower when parked, happens a couple of times then nothing for a week.
Compressor had a new piston ring fitted after this started happening. Car rises and lowers normally when not in fault mode.
Any ideas ?
Cheers
2002 4.4 FF
Post #542318 29th Jan 2020 7:55pm
pcourtney
could be height sensors gone a bit wonky, can you get the car to anyone that has a GAP IID tool, and plug it in, that is really the only way to be sure
Duckworths has a special for forum members, around £400 quid if you think it might be a good investment to buy one, our early 2002 to 2005 motors are gonna have plenty of problems looming up down the road IMHO, and it is good to have a handle on it before you go and see the mechanic and you are able to tell him what the IID tool is coming up with
Post #542324 29th Jan 2020 8:26pm
iiDTool now £500
@ BMG
Probably the compressor, time for a replacement.... .
Post #542353 29th Jan 2020 11:09pm
pcourtney
easily serviced using Andy's repair/service kit £25 quid
http://www.bagpipingandy.com/
easy enough to do ( but sadly in this throw away and replace society we now live in, people will pay £500 quid for a new one
Post #542357 29th Jan 2020 11:34pm
pcourtney
he makes the Piston rings himself
http://www.bagpipingandy.com/manufacture.html
Post #542358 29th Jan 2020 11:39pm
BMG
Done the compressor piston seal, made no difference.
When not in fault mode ( have an icarsoft tool ) the compressor seems fine and will raise the car up ok
Post #542359 29th Jan 2020 11:53pm
@BMG
You can get bare compressors on eBay from £120 - £200
https://www.ebay.co.uk/sch/i.html?_from=R4...p;_sacat=0
If it is the original compressor on your gen 1 L322 then it has done well to get you to here!
@pcourtney
Yes, one could:
Check function and operation of all airbags, height sensors
Check all pipe work for connections and leaks
Remove reservoir check for leaks, replace pressure relief valve, dismantle valve block (repair) and test
Dismantle front and rear valve blocks (repair) and test
Change piston ring in compressor, dry out the dessicant, ensure exhaust flow is clear, check function and operation
Have ECU tested, check wiring continuity
Check switch pack for function and operation
Then: get a new compressor!
"My comments are only based on my opinions and vast experience" .
Post #542379 30th Jan 2020 9:20am
pcourtney
Joe90 wrote:
iiDTool now £500
Island 4x4 still have them for £360 exvat ( £432 inc vat ) - but Duckworths were £405 last year !
https://www.island-4x4.co.uk/integrated-in...27303.html
Post #542402 30th Jan 2020 11:04am
@pcourtney - you said:
Post #542404 30th Jan 2020 11:12am
pcourtney
yep, Duckworths sold them to us for £27 quid less than Island 4x4 did last year, but now Island 4x4 are cheaper
I was just pointing out your £500 was a little wide of the mark Whistle
Post #542408 30th Jan 2020 11:21am
Oh dear Wink
https://www.fullfatrr.com/forum/topic54232.html .
Post #542420 30th Jan 2020 12:33pm
pcourtney
but why would you buy from Duckworths when Island 4x4 are £68 quid cheaper - yawn
Post #542673 1st Feb 2020 5:44pm
