Home > Maintenance & Mods (L405) > Does anyone want a winch mount for L405?
Page 3 of 5 <12345>
BlackPerth
Australia 2017 Range Rover Vogue SE SDV8 Mariana Black
Charles89 are you going ahead with manufacturing a few more? 2017 Range Rover Vogue SE SDV8 (with e-diff)
2012 Range Rover Vogue TDV8 Luxury (SOLD)
2010 Land Rover Discovery 4 3.0 TDV6 HSE Stornoway Grey (SOLD)
2006 Land Rover Discovery 3 SE 2.7TDV6 Black, G4 Challenge Copy (gone)
Post #539567 6th Jan 2020 12:12am
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
Ok so quick update after a couple of months of use. I have used this reasonably extensively and can say with confidence its grossly over engineered Rolling with laughter its solid, and very tank like.
I am satisfied I can start production of these and make them available to forum members. One slight modification is to widen the channel to allow for a variety of winches to be mounted. The hole patterns are industry standard but winch dimensions fo vary, so we will allow for an additional 20mm of clearance
I will start pricing up options for UK delivery and also over seas. Black Perth, I will price everything up for you this week and comeback to you with a price to ship to Australia I will also include a mount for CB radio antennas above the D shackle
Post #539689 7th Jan 2020 7:49am
Oli
Australia 2015 Range Rover HSE SDV8 Fuji White
Hi,
Nice work on the winch mount. I want one for my RRS.
Any idea if it will also fit a sport?
Post #541685 23rd Jan 2020 11:40pm
Charles89
I am not sure about a Sport. Its entirely possible that the sport and full fat share the same front end architecture. Perhaps someone on the forum can advise? I have never owned a sport so I am not best equipped to answer.
If the crash bar is the same as the L405 then I dont see why it would not fit.
Is anyone in the UK interested in these?
Post #542025 27th Jan 2020 9:01am
oli, read this from the RRS forum,
https://www.rrsport.co.uk/forum/topic54452...inch+mount ... - .- -.
Post #542030 27th Jan 2020 10:04am
Charles89
I should point out this is L405 not L322 I'm sure you can likely buy an off the shelf solution for the L322.. but not the L405
Post #542040 27th Jan 2020 10:40am
CMW
United States 2015 Range Rover 5.0 SC V8 Fuji White
Hi Charles, awesome job!! How did you wire the winch? Did you just wire it to the jump terminals under the hood (I'm in the US) or did you run an additional set of heavy gauge wire back to the battery?
Post #542220 29th Jan 2020 8:26am
Charles89
Exactly that yes, directly to the jumpers. The cable used on the jump point is very heavy gauge wire and more than capable of dealing with the current from the winch.
The only draw back is under heavy load I.e. winching up a hill, or winching another heavy vehicle is that it throws an alternator fault on the dash because of the current draw. But as soon as you turn the engine off and back on again its absolutely fine.
I have not figured a way around this yet, as usually its resolved by adding an extra battery... but there is no space for an extra battery anywhere...
Post #542227 29th Jan 2020 9:01am
Oli
Thanks Charles & Stan,
To be clear I have a L494 RRS SDV8 Dynamic with low range, e diff locks etc not the L322.
I can see there are winch mount options for the L322 around but I still can't find anything for the L494.
I suspect the full RR L405 would be a close match since it also has the aluminium Chassis.
Here in Sydney I get the cold shoulder from all the usual Off Road suppliers when asking about winch mounts etc. They seem to think that Range Rovers have no place off road! Sad given I've done plenty of remote trips in other vehicles and I can say for sure that none are close to the RRS in off the shelf capability. I'm even comfortable with the reliability but it's seriously frustrating that I can't get the extra comfort margin from having front and rear bars, winch, long range tank, spare tyre mount etc etc. Maybe one day but I have an upcoming trip to Lorrella Springs in the NT this July and I want it all now.
If anybody can confirm that the proposed winch mount could fit a RRS L494 I'm all ears.
Post #542363 30th Jan 2020 1:20am
Charles89
Shipping and cost are the biggest issue. I priced up shipping to Australia for another forum member and it was over £400 because of the size and weight
Looking online the crash bar that sits behind the bumper are being advertised and sold as L405/L494 so I assume the crash bar must be the same on both vehicles. I am confident it will fit the L494, what I am unsure of is just how much bumper you would need to cut in order to accommodate it Shocked
For me I was not fussed because second hand replacement bumpers on ebay are cheap
Post #542364 30th Jan 2020 7:22am
Charles89
We are starting our first manufacturing run of these week commencing 10th of Feb 2020. They will be available and on sale from the following week. Prices as follows:
Bare Winch mount, corrosion protected and finished in black as pictured on this thread £750. Including delivery to UK Mainland. Fitting as an optional extra is an additional £350, and we will need the vehicle for 2 full days.
Winch as used in this thread with synthetic rope £540 including mounting hardware, isolator, and wiring etc. Complete package including all the accessories, snatch block, strips, supply and fit everything as pictured £1690
Post #542365 30th Jan 2020 7:36am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi, Charles
Would it be possible to send out drawing and specs to someone out of the country with the small charge to your self for exploratory work that you have done to cut the cost of shipping and import duty? Just an idea.nice work Thumbs Up
Post #542374 30th Jan 2020 8:46am
Charles89
Quite possibly yes. I will speak with the engineering company and see if they are able to make some speciality drawings that perhaps an engineer in Australia can follow
Post #542375 30th Jan 2020 8:48am
BlackPerth
That would be great Smile I'm certain some guys in Australia (like https://www.aptfabrications.com.au) would be interested.
cheers 2017 Range Rover Vogue SE SDV8 (with e-diff)
Post #543298 7th Feb 2020 5:49am
Oli
Hello Charles89 & BlackPerth,
Can I ask if anything came of this?
Do we have someone is Australia that can manufacture the mount?
Post #544655 21st Feb 2020 4:37am
Page 3 of 5 <12345>
