Home > Technical (L322) > 2008 RR Pride and joy limp mode
v3mmtrangerover
United Kingdom 2008 Range Rover Vogue SE TDV8 Mariana Black
Hoping someone might be able help with an ongoing problem with my 2008 TDV8 RR Vogue SE only done 82K
Driving along with no problems hit 40mph and then fault warning and the following list of faults come up:
Engine system Fault
Suspension Lowered
Transmission Fault - Limited Gears only
HDC Fault - system not available
I've searched YouTube and google but cant fined anything I have also had it plugged in but no joy Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry
Post #542211 29th Jan 2020 4:54am
Poprivit
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
When I had this on my disco 3 it was a front wheel bearing that caused the speed sensor for the abs to trip a fault. Get someone with a diag tool to watch the live values and that should help confirm.
Post #542224 29th Jan 2020 9:43am
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Similar warnings came up on my RRS when the battery was on its way out. New battery, codes cleared and never had the same issues again - plenty of others mind you Smile Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #542225 29th Jan 2020 9:55am
v3mmtrangerover
so the Landy garage had it for 6 weeks injectors etc no joy I bought a used low mileage HP Pump fitted it in 1h and boom like a fecking train cheers for all the help gents
Post #560951 11th Jul 2020 5:39am
