Home > In Car Electronics (L322) > Simple questions- is there an easy way to have aux input....
NVB
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
......for music on a 2005my L322 with touchscreen MOST infotainment system.
I simply want to be able to plug my iPhone in to listen to my tunes. It can't be that hard, can it?
I have searched but am getting confused with all the different systems the L322 had installed during its lifespan. RR History
1988 2.4td Classic 1999 to 2020
1992 3.9efi Westminster Classic 2004-2005
2005MY L322 3.0TD6 Vogue 2016 to current
Post #541647 23rd Jan 2020 7:52pm
Weegie
If you have an auxiliary socket in the rear seat heater control panel, you can buy a lightning (or 30 pin) to 3.5mm stereo plug adapter which you plug into it. Then select Aux on the screen.
This allows you to play your music but the volume control requires turning right up. Also it doesn't charge the iphone.
If you don't have the auxiliary socket then there isn't an "easy" way to do it. John
GAP iiD BT
Post #541658 23rd Jan 2020 8:53pm
NVB
Thanks Weegie. Anything less than simple is probably not with bothering with.
I bought a Dice unit off eBay but understand it only works with pre-MOST L322's
I have read about a LR part VPLME0004 that seems similar to Dice for MOST equipped cars but can't find one for sale anywhere. RR History
Post #542007 26th Jan 2020 9:00pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Re: Simple questions- is there an easy way to have aux input
What about a 3.5mm to bluetooth converter. Plenty on ebay and then you can keep your phone charging too.
Post #542010 26th Jan 2020 9:23pm
Weegie
Duckworths had some for sale when Dan was there. You could ask Sophie, who took over from Dan, if they have any left. He was moving old stock I believe. John
GAP iiD BT
Post #542021 27th Jan 2020 7:29am
