Home > Technical (L322) > FBH still running when engine warm 3.6 TDV8
MarianaWestminster
Hi all,
I've noticed recently that my FBH comes on when I start the car but even after a good run (1 hour plus) with the engine fully warmed up the FBH is still running.
Is this the correct operation?
Many thanks
Post #541827 25th Jan 2020 9:20am
Weegie
Doesn't seem right. Mine switches off after a relatively short time. John
GAP iiD BT-Sold
Post #541840 25th Jan 2020 11:49am
MarianaWestminster
I imagined it would turn off when a certain coolant temp was reached.
Checked the coolant temp with my new IID tool after the 1:20 journey and 3 minutes idling it was showing 82 degrees C.
Will have a look at the workshop manual
Post #541841 25th Jan 2020 12:00pm
kevinp
Re: FBH still running when engine warm 3.6 TDV8
MarianaWestminster wrote:
Hi all,
Many thanks
I think mine is to. I just drove 3 miles and parked up for 10 minutes. Then drove a few hundred yards and parked up to be greeted with a cloud a diesel smelling smoke coming from the wheel arch.
Post #541843 25th Jan 2020 12:10pm
MarianaWestminster
According to the WSM the FBH runs in auxiliary heating mode until one of a set of conditions is met.
One of these conditions being the engine coolant temperature exceeding 75 degrees C.
I will test again later when I go out.
Post #541844 25th Jan 2020 12:24pm
MarianaWestminster
Post #541845 25th Jan 2020 12:24pm
kevinp
Post #541846 25th Jan 2020 12:30pm
