![]() | Home > Maintenance & Mods (L322) > Replacing HPFP - what else should I do ? 165k 2005 TD6 |
ShuntL322 Member Since: 21 Dec 2019 Location: Acle, Norfolk Posts: 18 ![]() ![]() ![]() |
Worth changing the glow plugs when your in the area.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 806 ![]() ![]() ![]() |
I would be having a very close look at the hoses going to the HP pump, making sure the ends of the hoses are ok and the worm drive clips are tight. 2007 TDV8 VSE
bigpatty Member Since: 13 Dec 2019 Location: Morbihan Posts: 3 ![]() ![]() ![]() |
Thanks guys. Useful info.
I had a similar leak and thought the worse so I kept putting it off. When I got round to checking the hoses I found the ends degraded and the clamps not tight. Hoses trimmed, new clamps, a bit of a cleanup and all good. Max 30 mins. I hope you are as lucky. I think if the actual pump leaks you will get diesel fuel in the engine oil so give that a sniff if you are concerned. 2007 TDV8 VSE
Wayneg.
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 ![]() ![]() ![]() |
Good work. Hope it's sorted! |
bigpatty, glad to hear you had a result. I recal using a 1/4 drive ratchet with a flex extension to get at the clamps. The rubber had degraded on mine and become soft and swollen at the ends, presumably allowing the clamps to dig in and become loose. I just cut off 10mm from the end and new quality clamps.. 2007 TDV8 VSE
