Home > Technical (L322) > Diagnostic tool
mudknight
2003 Range Rover Vogue Td6 Java Black
Diagnostic tool
Hi , I've been told there is a blue tooth diagnostic tool that connects to an app on a phone , I mainly need it to clear faults on a 2003 l322 , suspension inactive keeps occurring but mechanic can't find out why . Anyone have any info on these ?
Thanks
Post #541213 20th Jan 2020 6:19pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
GAP IID diagnostic
https://www.gap-diagnostic.com/products/iidtool/ Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #541216 20th Jan 2020 6:29pm
DrRob
Cheapest place is island 4x4 Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #541223 20th Jan 2020 7:56pm
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
If you can find someone local and willing on the forum they can add your VIN to their GAP IIDToolBT for less than £100 to give full functionality, but to just read and clear codes then any GAPIIDToolBT should work already.
BTW have you tried the steering wheel turned lock to lock (with engine running), this sometimes bizarrely clears the suspension fault (kind of a domino effect of errors I believe)?
Post #541228 20th Jan 2020 8:35pm
mudknight
Thanks for the advice , yep tried the lock to lock trick but no good on this fault . Been looking at hawkeye red dongle . Anyone know if any good ?
Post #541230 20th Jan 2020 8:41pm
DrRob
Britpart Lynx is almost as same full functionality as IID Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #541232 20th Jan 2020 8:49pm
Gsxr1250dave
Erm
Buy a hawk eye cheap enuf 2nd hand on the bay or get the reset plug in tool 70 quid
Post #541238 20th Jan 2020 10:09pm
fenlander
You may eventually find the fault is one or more ride height sensors, these are Hall Effect devices that do eventually wear out and give zro or "implausible" values to the ECU hence the error message- a (relatively) cheap fix that can be done without removing the front wheels, though again you will need some form of suitable diagnostic tool once the parts are replaced.
Post #541241 20th Jan 2020 10:31pm
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
icarsoft LR V 2.0 is around £130 and will read EAS codes ,clear them and provide live data.
Not sure what the GAP tool does over this, anyone know ?
Post #541244 20th Jan 2020 10:57pm
4040
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
That would be good to know. I have read on here that the gap can customise certain features but some don’t wish to do that and just want a decent fault finder for a more reasonable cost. So from a diagnosis side the difference would be good to know
Post #541251 21st Jan 2020 12:03am
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Foxwell nt 530 will read and clear codes, reset steering angle sensor, gearbox adaptions, alter suspension heights and a few other things I havent got round to looking at yet.
Post #541253 21st Jan 2020 12:19am
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Autel AP 200 Bluetooth here, seems to do all of the above so far, linked to my onboard Android tablet.
and only £70 for the entire Landrover line. Very Happy
Post #541264 21st Jan 2020 7:58am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
RichM63, can you confirm the Autel can change suspension heights permanently. Can it also do things like stop bulb testing 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #541266 21st Jan 2020 9:22am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I have the earlier iCarSoft as well as an IID BT from Gap. In terms of capability the IID can also calibrate suspension heights (I know my iCarSoft can't do this, the V2 may be able to) and modify the CCF, flash modules etc. It is also a heck of a lot easier to use - they've put an enormous amount of effort into usability and it is a pleasure to use.
Having said that, the iCarSoft is an excellent tool it's just a bit fiddly, slow and awkward to use compared to the IID. I'm sure the V2 is better and if all you want to do it read / clear codes then it's well worth the money.
There are some on eBay - they make a good 2nd hand buy. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #541274 21st Jan 2020 12:10pm
RichM63
I bought the Autel AP200 in order to have a reader permanently in the L322, with full live data onto my Android tablet.
Certainly it seems to check every module etc inc bulbs, and even the CD/Radio player
I don't know if it can calibrate/change suspension heights as I have no reason to try this out, have Wurth, ICarsoft etc available if required.
However; I will fire up the Autel and look at what is on offer for the suspension.
best Rich
Post #541325 21st Jan 2020 8:03pm
