Home > Technical (L322) > [solved] soot increase when accelerate (with warm engine)
flashgordon
Germany
Hello
unfortunately one more question regarding soot accumulation:
I found out with IID tool that there is almost NO soot accumulation
when operating water temperature is still < 100%
and even short after very low soot accumulation (picture 1).
I always assumed a cold engine is bad......
13 km (8 miles) city traffic / 25 minutes: 0,3 g soot increase -- very good --
direct retour - same distance- very warm engine
I could see whenver I accelerate soot accumulation goes up: 2,5 g -- not very good --
and only smoothest/slightest/most careful acceleration. (picture 2).
by the way. that was only on my way back with warm engine - no problem on the first 8 miles.
same driver - same route - same driving style - same traffic conditions
What would you look for?
- I have already done a smoke test ( a small leak was found and fixed in the last weeks)
- difference pressure sensor is new
- maybe full particulate filter? will have it externally cleaned I think
- because soot increases when I accelerate: something with the throttle?
let's have a nice new week then...
Post #541095 19th Jan 2020 9:06pm
GGDR
how many miles 'regeneration range' ?
From low grams to 20 or 23grams?
or in other words from regeneration to next regeneration?
also you might need to do a high pressure smoke test.
low pressure smoke test does not seem to find all the leaks.
. Cheers, Greg
Post #541097 19th Jan 2020 9:16pm
flashgordon
Germany
It depends:
- COLD engine ( +/- 8 miles, even city-traffic, even a lot accelerations) = no soot increase = very long distance
- WARM engine + ACCELERATION = problem, max. 50 miles between regenerations
(soot increases only when I accelerate , no matter how smooth I accelerate)
- WARM engine + CONTINIOUS driving = OK, 150 miles between regenerations
Post #541104 19th Jan 2020 10:14pm
GGDR
ok I see - and when you get 150 miles (thanks for working in miles!) what kind of driving is it?
Don't think it matters too much, I think you may have an air leak.
Could be anywhere in this pretty complicated system:
Worth checking your CSOV valve (search you'll find it) for free operation too.
Can you pls link your previous threads too?
(might be better to continue the old one)
Because I remember something about your throttle body.
. Cheers, Greg
Post #541109 19th Jan 2020 11:26pm
flashgordon
Germany
thanks Greg for the picture once more.
Yes, you are right: I had a similar post before ("soot increase within minutes")
https://www.fullfatrr.com/forum/topic53751.html
That problem has been fixed (2 leaks lead to dramatic soot increase and a "red" within minutes).
Post #541236 20th Jan 2020 11:04pm
GGDR
You may still have an (another) air leak flash.
High pressure smoke test may be needed
. Cheers, Greg
Post #541356 22nd Jan 2020 12:22am
GGDR
and did you get the turbo drain modification done?
. Cheers, Greg
Post #541357 22nd Jan 2020 12:24am
flashgordon
Germany
---> YES, will do that as soon I find time
And did you get the turbo drain modification done?
---> YES, is done.
I am very happy with it.
my impression is, I feel the extra-power from the 2nd Turbo 100-200 RPM earlier than before
and it feels a little smoother than the Turbo-punch before....
Post #541429 22nd Jan 2020 4:26pm
flashgordon
Germany
I hope I solved the soot/DPF issue:
I finally changed the gasket between throttle and manifold because there was a little soot blown out,
part number is LR022931 only 2,-- GBP
For this I had to remove the throttle - and it was obvious a liitle oily/sooty - one side more than the other
And I cleaned the other pipe that (as I think) comes from the EGR with hot exhaust air (and soot).
Unfortunately 1 of the 4 throttle screws felt down in the enginne bay but not to the groung. So I bought a new for roughly 7 GBP instead removing the plastic cover beyond the engine bay and looking for the missing screw.
Result:
A test drive afterwards showed improved soot-values.
The critical point in the past was after 8 miles or so when engine was hot:
Soot-values increased at each (even moderate) acceleration at each traffic light for 0,2 - 0,4 g before.
Cleaning / new gasket reduced improved the situation:
Soot-value still increases when accelarating at a traffic light but only around 0,02 - 0,04 g now.
--- significant better for me.
I assume 0,0 g soot will be impossible then du to the engine-emission-design ...
BTW:
If you should be interested in these details I would like to know if you experience similar increased (0,02-0,04 g at each start at a traffic light and at operating warm engine temperature). I would like to find out what it could be in best case.
Thank you for your write-up how to remove the pipe/hoses carefully. I wouldn't have done this without this help.
I wished I was more brave and would have cleaned the manifold but this seems to be much more work
than to loosen only some screws and two hoses.
Post #541884 25th Jan 2020 6:58pm
