Definitely character
Simple first:
Try a hard reset first, i.e. let the car shutdown over several minutes, disconnect the battery at the terminals and touch the cables together for several seconds. Reconnect and see of that works.
Fuses are easy to check, the list is in the owners manual and the fusebox for them is in the back of the glovebox. If you don't have the OM, a copy is in the Wiki.
Suspension should not lower whilst paused at lights I think. Did this start after the battery change? Again try again after the reset.
No luck on that, come back. Cheers
Richard
Gap IIDBT
