Home > Technical (L322) > Trailer tail lights
bishbosh10
Trailer tail lights
I have noticed a problem with my tow ball mounted bike carrier.
I thought it was the bulbs in the carrier - some numpty parked too close and cracked both lenses so I thought cold water and hot bulb = blown bulb. Indeed on investigation they both were blown but replacements have not solved the problem.
So, I got my trusty multimeter out and have determined (I think!) that I have no power coming from the car's 13 pin electrics to the two pins that make the tail light circuits.
My question is does the RR have a separate fuse panel for the towing electrics and if so would it fuse each trailer circuit individually as the rest of the lights work as they should?
Seems a bit odd for both tail light circuits to fail at the same time unless the bulbs blowing caused the fuse(s) to go too?
2011 MY with factory towbar.
Any thoughts of where to prod around before I get an auto sparks in? Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #536078 1st Dec 2019 3:03pm
rjff
Try the rear junction box fuse 8R and relay 3R. I think you can change the relay for one of the others to check operation.
The WM is in the Wiki if it helps.
And also check the wiring of the tsilerboard/cycle carrier. It may damaged unseen Cheers
Richard
Gap IIDBT
Post #536087 1st Dec 2019 3:44pm
bishbosh10
Sorry for the delay in replying - finally got some post Christmas headspace to investigate.
Sadly F8 is fine and I have swapped R3 for another one with no change. Sad
Any more ideas please? WSM seems to be rubbish on towing electrics. Bish.
2005 110 TD5 CSW
Post #540483 13th Jan 2020 7:23pm
rjff
Hi Bish
Discconnect the fitting in the spare wheel well and see of the wires corresponding to the lamp wiring in the trailer supply socket on the car are giving a correct reading, if you follow me. That will tell you if the car is supplying the power or that the wiring loom to the car socket is faulty. This assumes the car was specified with a tow prep when ordered.
You can tell that if the car has a grey socket with 13? connections in the spare wheel well, NS rear of the well. Cheers
Richard
Gap IIDBT
Post #540500 13th Jan 2020 10:24pm
eyrie
left and right tail lights are fed from separate pins therefore a failure of both together is unlikely
Have you check the earth?
Post #540727 16th Jan 2020 1:43am
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
any update on this
mine has the same problem
bong of doom, check trailer lamp=
no side lights on trailer but indicators/stop lamps working fine
13 pin towing electrics
all fuses appear fine
Post #541239 20th Jan 2020 11:15pm
bishbosh10
Not yet - hope to get some time over the weekend to prod about as rjff suggests.... Shocked
I don't have any warning messages though...... Bish.
2005 110 TD5 CSW
Post #541589 23rd Jan 2020 2:28pm
rjff
Bish
I'd also go with checking the earths and if you have access to another trailer/light board/cycle carrier check using that. And check your carrier on another vehicle with known working lights. Cheers
Richard
Gap IIDBT
Post #541599 23rd Jan 2020 3:18pm
bishbosh10
It is definitely the car - I have put the rack on a friends disco 4 and all worked as it should. I have also tried another 13 to 7 pin adaptor and had the same symptoms.
Hopefully I'll get some time at he weekend to try everyone's suggestions.
Thanks for the input! Bish.
2005 110 TD5 CSW
Post #541724 24th Jan 2020 2:20pm
ironhorse
ok
trailer tail lamps have packed up
all other trailer lights work ,indecators,stop lamps ect
done a bit of testing and this is what i have done/ found
1 ive checked fuse 17 in boot(fuse is ok ) and checked there is 12V at trailer ECU plug, red/white wire,this is the main permanant feed to trailer ECU
2 then turned lights on and checked i have 12V in the slate/white whire at ECU plug ,this is the feed from the light switch to the L/H trailer tail light (all good so far)
3 then checked slate/black wire out of the ECU that feeds pin 7 in the trailer plug 0v on that wire
4 done the same for the R/H trailer curcuit ,slate/purple into ECU 12V
5 0V out of ECU on slate/red to pin 5 of trailer plug
6 disconected ECU then put a 3amp fused jumper between slate and white wire and slate and black L/H trailer light is now working
7 done the same with slate and purple and slate and red ,R/H trailer ls also working
so looks to me like trailer ECU is knackerd
orderd one just waiting for it to arrive, ill let you know if it sorts it
was just going to bridge the termenals out inside the ECU if i need to tow before it arrives
mine is a 2005 loom so some of the wiring colours did not corrispond to diagram below (wires out of ECU to trailer plug was different)that was confusing to start with
Post #541786 24th Jan 2020 8:44pm
ironhorse
only had the message 1 time
Post #541787 24th Jan 2020 8:48pm
ironhorse
Happy days new ECU has sorted it Thumbs Up
Now got sidelights again
Post #541849 25th Jan 2020 12:54pm
pcourtney
well done - how much was the ECU ?
Post #541851 25th Jan 2020 1:04pm
ironhorse
35 quid second hand off flebay
95 brand new
Post #541860 25th Jan 2020 4:01pm
bishbosh10
Today's update -
Disconnected the multiplug in the boot and checked the pins on that. They give exactly the same results as the trailer socket itself so the problem is definitely upstream of the multiplug. Sad
Any more clues? Bish.
2005 110 TD5 CSW
Post #542786 2nd Feb 2020 5:12pm
