Home > Technical (L322) > Best replacement battery?
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
My battery was dead again this morning. I suspect a couple of hours cleaning it at the weekend (doors open) and then sitting on my drive for a week did for it.
I think the battery has lost its ability to hold charge so I'd like to buy the best (and biggest) one I can find. Any recommendations?
I'm also considering the auxiliary battery installation. Anyone know who can do this?
Post #54044 11th Mar 2011 10:05am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
When you buy your new battery also invest in one of these from maplin, they are having a clearance sale of them at the moment and want £9.99 a piece. Mine worked faultlessly for 3 months when the car wasn't run last year, even when the windscreen was covered in snow there was enough light to keep the charger running
http://www.maplin.co.uk/solar-powered-12v-...4qodnbyjdg 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #54046 11th Mar 2011 10:23am
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
thanks Tim Thumbs Up
Post #54048 11th Mar 2011 10:31am
Just bought one online thanks Thumbs Up
Post #54065 11th Mar 2011 11:44am
Reformed
Do these plug in the lighter socket or power points? Reformed
Post #54108 11th Mar 2011 3:22pm
both . Wink ... - .- -.
Post #54110 11th Mar 2011 3:26pm
Emperor Mong
To bring this one back on track... I think the battery has lost its ability to hold charge so I'd like to buy the best (and biggest) one I can find. Any recommendations?
Post #54112 11th Mar 2011 4:11pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi - Just bought one 2 weeks ago. Got it online and it was an Varta 110ah 920cc. Bigger than the one LR suggest at only 820cca.
http://www.tayna.co.uk/610-200-Varta-Silve...P3200.html
Got it from the folks above with a couple of days for delivery. Great service and battery (although a tight fit) is perfect for the car. I went for the bigger 920cca for those cold mornings.
HTH
ps - They are heavy and a bit of a git to fit with one person but doable. Make sure you put the bonnet into service mode and have a small set of steps available to help git the old one out and the new one in. Ash
2016 SDV8 AB
Post #54116 11th Mar 2011 4:44pm
Emperor Mong
Thanks. Looks perfect.
Post #54117 11th Mar 2011 4:57pm
if you have a local europarts near you , they have these batterys as well with the added advantage that if the battery goes wrong , and being local , you can take it back .. ... - .- -.
Post #54140 11th Mar 2011 5:50pm
Paul J.
comports wrote:
I went for the bigger 920cca for those cold mornings. .... (although a tight fit) is perfect for the car.
'Tight fit' is an understatement!!
Just put in a Bosch 110Ah / 920cca from Eurocarparts. My knuckles are skinned and my back is sore. Laughing
Hope the extra capacity will be worth it. Thumbs Up
Paul
Post #104643 31st Jan 2012 6:14pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Hi
I bought a varta about 2 months ago and it's been a massive
Improvement
Try these
http://www.battery2u.co.uk/type-I1-varta-car-battery-silver.aspx
Very fast delivery RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #104691 31st Jan 2012 9:00pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Gents I bought a Varta I1 last year and its worked a treat up til now, think a drain has killed it as had it charged a coupel of times but keeps losing it again
Will they company replace it? (I know it was possibly my/my cars fault) Or buy another one and try sending the old one back? Naughty I know but thought I'd ask
Post #104702 31st Jan 2012 9:29pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I seem to recall that Varta batteries have a 3 year warranty. It's certainly worth a try. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #104712 31st Jan 2012 9:44pm
Had one of those solar trickle chargers for a few years.
Only works if its plugged into a socket with constant live as I recall, so you need to plug it into the one in the boot Discovery 4 HSE
Post #104715 31st Jan 2012 9:47pm
