![]() | Home > General (L405) > Which L405 MY hits the sweet spot? |
Can't fault our 2014MY 3.0 TDv6. Into 3rd year of ownership, covered 26,000 miles in that time and it has been superb in every way. No infotainment issues. No other early model issues in our case. Diligent routine and preventative maintenance has been all that is necessary. 3.0 engine is superb in every way. Had 4.2SC and 4.4TDV8 in L322 guise prior to the L405 and would buy another 3.0 L405 again without hesitation. |
SS.Lyria Member Since: 01 Dec 2016 Location: London Posts: 257 ![]() ![]() ![]() |
Can’t fault our MY15 L405 so far, but we’re only 3 weeks into ownership |
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 ![]() ![]() ![]() |
My 2017 MY has had two oil leak issues causing saturation of the wiring harness controlling the boost solenoid. In between the first and second repair there has been a modification which should mean it won’t happen again. Initially had an issue with a stuck (newly fitted) deployable tow bar. Apart from that it’s been brilliant. V8 is sublime and power is smooth and effortless. Mpg on a run is consistently over 35 but reduces to about 22 around town. Towing is about 20 but my caravan is 2500kg so similar to my D4. Infotainment is a huge step up from what went before. |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
New MY16 owner here, happy so far |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7968 ![]() ![]() ![]() |
2013 - my lower tailgate has stopped closing electrically - so I push it up manually.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
From a technical standpoint the 15MY> have the greatest revisions to the CAM BUS & LIN BUS systems... Have the revised suspension fitted from factory so, in theory they should be the best bucks spent sir |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
And then MY17 has a much improved infotainment system, while retaining all of the positives of the early cars, like proper & lidded door bins, an analogue lower centre console, comfier head restraints in the AB, split view front screen, a CD/DVD player, side marker lamps and steering wheel controls with more tactile feedback.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
i looked at the late 15 FF's onwards ..the tax is cheaper and as Red Merle has said, they are euro 6 .. ... - .- -.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
I quite like the seat adjust controls high up and accessible on the door card rather than by feel on the seat.
Mariana Black Member Since: 30 Jul 2014 Location: Stockton-on-Tees Posts: 89 ![]() ![]() ![]() |
Owned 3.0L from new.
@greg..could be 2018'ish.. ... - .- -.
As Stan says, but definitely MY 18 onwards.
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
When did AdBlu come in? MY16?
Adblue came in with Euro 6, MY 16. |
