Home > General > Where are all the nice L322s?
EVOeng
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I've recently been in need of a car to lug stuff around - my estate car isn't long, wide or tall enough so I've been looking at getting another low mileage (sub-65k), low owner, early (pre-2005) V8 petrol L322. There doesn't seem to be any for sale. Even when expanding the search to a 4.2 Supercharged, very few are tidy. I remember 12-18 months ago, I was tripping over nice ones. Has everyone decided to keep theirs?
Post #538002 20th Dec 2019 2:19pm
If they ain't broke and all that! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #538020 20th Dec 2019 4:54pm
Gsxr1250dave
Yep
Mines a keeper 92k miles on the clock and mint
Post #538041 20th Dec 2019 6:17pm
TomV8
United Kingdom 2004 Range Rover Vogue 4.4 V8 Bonatti Grey
There is a nice Epsom green, one owner 60,000 mile one on Autotrader at the moment. I think it is on for £8,999.
Post #538062 20th Dec 2019 10:23pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
For what was lurking under the plastic sill trims and what is visible on some photos on vehicles for sale on Ebay , a lot will end up being scrapped due to corrosion !
Post #538075 21st Dec 2019 7:30am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
It’s not just the earlier ones, I’ve had several 2010/2011 L322’s over the last couple of years, all with some degree of rusty rear arch lips and corrosion under the plastic sill cover / wheel arch liner, I came to accept it as part of the ownership experience!
I doused with Dinitrol products including spraying it through the handy holes in the sill when the plastic cover is removed in an effort to keep the rust at bay.
With this said, I also had a 2009 L322 with similar mileage that had zero rust in these areas and no apparent repair / paintwork, I can only assume it’s down to the life they’ve led.
Post #538078 21st Dec 2019 9:00am
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I sold my 2004 TD6 Vogue last year for 12k. Obviously that's a lot of money, but as a one owner with just 41k on the clock, full main dealer history, little or no corrosion, a perfect interior and genuinely no issues throughout its life I'd say it was great value for money
Post #538744 28th Dec 2019 9:43pm
Keeping my 12 for a while yet. Not seen the point in changing it for a 405 yet.
Quite fancy the new defender....... Whistle There is nothing that can't be fixed with a hammer😜😜
Post #538752 28th Dec 2019 10:39pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Keeping my 11 for some years to come
Post #539084 1st Jan 2020 11:04am
DrRob
Keeping mine for a few years - especially after new secondary turbo just fitted Thumbs Up
Job for spring = remove sill covers and fill with waxoyl Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #539086 1st Jan 2020 11:20am
TDSIX
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
What would a 2005 TD6 with 52000 miles in nice condition be worth today? 2010 FF 4.4 TDV8 Vogue - Gone
2007 FF VSE 3.6 TDV8 - Gone
2011 RRS HSE 3.0 TDV6- Gone
2003 FF TD6 Vogue - Gone
2006 FF TD6 - Gone
2007 FF 3.6 VSE - For sale
2011 FF 4.4 TDV8 - Current
Post #539553 5th Jan 2020 10:08pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
I've just been looking for one on eBay and all the ones that took my fancy are miles and miles away. First time FFRR owner
Post #539560 5th Jan 2020 11:06pm
EVOeng
Even the 1 or 2 low mileage, low owner cars are very rough. I would expect that MOT advisories are usually dealt with the next time a car gets serviced but some cars have the same issue year in, year out.
A 47k, 2 owner car for sale at a dealer has an MOT history that reads:
2014: Failed 1st test
- Mileage unreadable (dash screen needs repair)
- Front Brake pad(s) less than 1.5 mm thick (3.5.1g)
- Nearside Front Lower Suspension arm has excessive play in a ball joint (2.4.G.2)
- Offside Front Lower Suspension arm has excessive play in a ball joint (2.4.G.2)
- Nearside Front Anti-roll bar linkage has excessive play in a ball joint (2.4.G.2)
- Offside Front Anti-roll bar linkage has excessive play in a ball joint (2.4.G.2)
2015: Failed 1st test
- Offside Rear Wheel nut(s) missing (4.2.A.1e)
- Nearside Rear Road wheel slightly damaged (4.2.A.1a)
- Nearside Front Torque/reaction arm has slight play in a pin/bush (2.4.G.2)
- Offside Front Torque/reaction arm has slight play in a pin/bush (2.4.G.2)
- N/S/F Tyre torn outer sidewall, but within mot tolerance.
2016: Failed 1st test
- Offside Rear Wheel bolt(s) missing (4.2.A.1e)
2017: Failed 1st test
- Offside Front position lamp(s) not working (1.1.A.3b)
- Central Front Anti-lock braking system warning lamp indicates an ABS fault (3.4.1c)
Advisory notice item(s)
- Offside Front Headlamp damaged but light output not reduced (1.7.5a)
- Nearside Front Outer Tyre worn close to the legal limit (4.1.E.1)
2018: Failed 1st test
- Suspension system inoperative air suspension (5.3.5 (a))
2019:
- Nearside Front Tyre slightly damaged/cracking or perishing Outer sidewall (5.2.3 (d) (ii))
- Nearside Rear Tyre slightly damaged/cracking or perishing (5.2.3 (d) (ii))
- Offside Rear Nail in tyre ()
- Offside Front Brake pipe corroded, covered in grease or other material (1.1.11 (c))
- Parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (1.4.2 (a) (i))
I thought I found a nice supercharged 2007MY black car but it looks like its now sold.
Post #539611 6th Jan 2020 3:27pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I think that one is quite shocking that the mileage cannot be read for close on 5 years Rolling Eyes Shocked Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #539712 7th Jan 2020 1:44pm
TDSIX
Anyone? 2010 FF 4.4 TDV8 Vogue - Gone
2006 FF TD6 - Gone
Post #539850 8th Jan 2020 8:19pm
