Home > Technical (L405) > Wheel Alignment - what type?
pld118
Hello,
If getting the wheels aligned does it have to be/ should it be done via Hunters 4 wheel alignment, i.e. is it a specialist job for the RR?
Thanks.
Post #539709 7th Jan 2020 12:10pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
When I bought my AB from an independent I noticed it pulled very slightly left so they fitted new lower suspension arms on the front and new anti roll bar bushes. They then had a four wheel alignment carried out which showed green all round within tolerances. A few months later, I had new tyres fitted all round as the fronts were worn on the inside and rears were getting a bit thin. I decided to have a Hunter alignment carried out and despite no kerbing or similar, some of the readings were a fair way out. The operative did improve things, but said he couldn't get all adjustments within tolerance. That said, the car handles ok and I can't see any uneven wear on the new tyres. So in my case, was the first alignment really correct, and did the operative of the second alignment have the knowledge to adjust properly within tolerance ? In summary, I'd make sure it's done by someone who's familiar with the 405.
Post #539746 7th Jan 2020 5:28pm
what makes you think you need an alignment Ryan? ... - .- -.
Post #539749 7th Jan 2020 5:43pm
DrRob
Tight Tolerance Mode needed Thumbs Up
https://www.disco4.com/forum/new-tyres-ali...85839.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #539753 7th Jan 2020 6:00pm
charlie croker mk2
Might be a considerable drive for you but if anyone needs alignment in Yorkshire ? this guy is fantastic .
http://www.atec-align.co.uk/
Post #539765 7th Jan 2020 7:53pm
All MD's have to have a Hunter alignment machine as of 2016 ish...
So yes, i would always have mine aligned using a Hunter machine ONLY... Thumbs Up
Post #539774 7th Jan 2020 9:32pm
charlie croker mk2
Craig : I didn't know that , I have not been back to a MD for a few years !
Post #539779 7th Jan 2020 10:26pm
pld118
stan wrote:
what makes you think you need an alignment?
The very outer edges of the front tyres have slight shoulder wear Stan... And the steering wheel is very slightly off centre.
Farnell LR charge £120 incl vat for 4 wheel alignment and a local LR specialist charges £95 for it...
Post #539819 8th Jan 2020 11:15am
circa £100 seems the going rate for a hunters....imperial tyres here in swindon charged me that on my SC.. ... - .- -.
Post #539821 8th Jan 2020 11:18am
Mikey
Tight tolerance mode
Hunter system only
If you get a blank look at either of those requests, walk away Laughing
Post #539823 8th Jan 2020 11:29am
DrRob
Wot Mikey said Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #539837 8th Jan 2020 4:07pm
nwmgc
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
I was obliged to get two new tyres this weekend at KwikFit and they - I thought - kindly suggested a free check on the Hunter machine, saying they would charge only if an adjustment was needed at a standard price of £79.95 inc. VAT.
I could see the Fatty on the machine and the readouts were fed directly to the reception area where I was sitting. I could see it all being set up properly. The rears were bang on, but the front well off. Again, I could see the car, the operator and the readout as adjustment was made. I was rather impressed (low expectations, I suppose)! Thumbs Up
As an aside, in 2014, at a main LR dealer, I was told they were unable to perform 4-wheel tracking on my then 2006 Fatty due 'to its age' Rolling Eyes
Post #540659 15th Jan 2020 11:56am
good price that Thumbs Up ... - .- -.
Post #540660 15th Jan 2020 11:59am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
bit of a 'holy thread resurrection Batman' but thought I would just share my experience today with Kwik Fit
Quite impressed even though they did nothing.
I have approached them to do Hunter check plus balance 4 wheels as a (hopefully) fix to a slight vibration. The KF tech guy knew all about tight tolerance mode but also said they cant assist at that branch as I have adaptive cruise control (would also be the same if I had lane departure) Apparently to do the job properly these sensor need re calibrating after wheel alignment and the machine to do the job that cost £26K.
Only selected KF branches have this machine and thats trip for tomorrow.
He did quote £64.95 for alignment inc 4 adjustments and £6.95 per balance.
I appreciate the above thread touches on these point but this is the first time I have heard mention of ACC or Lane Departure sensors. Thumbs Up to Kwik Fit. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #649020 24th Nov 2022 12:56pm
Kot
Any idea Which selected branches? 2018 SE SDV8 4.4 Byron Blue
Post #649030 24th Nov 2022 3:39pm
