Home > In Car Electronics (L322) > How to remove touchscreen display Late Model L322 |
Jensenyte Member Since: 31 Dec 2019 Location: Yorkshire Posts: 2 |
Did you get any further with this, I’m having the same issues, there must be a way to get to the bottom fixings ?
7th Jan 2020 7:37pm |
Madlotus Member Since: 10 Oct 2019 Location: Cheshire Posts: 6 |
Hi, I've just changed the AC fan in my 2009 this included removing the touch screen amongst most other things. Your correct in needing to take the bottom glovebox out then the top glovebox out in order to disconnect and unbolt the airbag securing brackets, once the glove boxes are out of the way unbolting is simple, if I remember correctly they are 13mm bolt heads (2off them), you will lso need to remove the vents in the top of the dash as there are two screws under them, other this it's much the same as the video from powerful video. I'd give yourself 2-3 hours to strip and then rebuild. If you have any questions let me know.
7th Jan 2020 8:15pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7823 |
The 2010 onwards workshop manual is in the wiki. I know it’s not exactly the same, but it’s closer than the early dash videos.
7th Jan 2020 8:20pm |
