Home > Camping, Caravanning and Holidays > Dometic Freshjet FJ2200 roof mounted A/C fan speed issue |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1189 |
HI, Huw
7th Jan 2020 3:08pm |
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 |
Hi Alex
7th Jan 2020 3:29pm |
Huw, are you working in heating or cooling as the ambient temp will make a difference?? |
7th Jan 2020 3:36pm |
I’m operating the four individual speeds from the remote in manual mode. In cooling I’ve set it at 16° so it’ll run at full blast on automatic, which it does. It runs quietly in speed 1 but no change in 2, then 3 it blows very fast and 4 makes no difference. I used to get 4 distinctly different speeds but now only two. |
7th Jan 2020 3:48pm |
I understand what your saying? is it the same in heating with the fan speed? It may not be the unit it could be the remote controller? |
7th Jan 2020 3:52pm |
I'll give it a go and let you know. I'm doubtful as it seems only to work in the 2 speeds automatically too. |
7th Jan 2020 4:40pm |
Ok so here I am having tried the reset and even removed the PCB to send off for repair. It came back looking like a number of relays had been replaced (the solder looked shiny on the back) stating there was water damage. The fact that Dometic advised the PCB was the problem and that water ingress was the likely issue smacks of not being fit for purpose to me but we'll see. I refitted the PCB and the fan no longer runs at all but a different fan does run at all four speeds which is confusing. I have air being blown out of the vents on top of the van but the fan to blow into the van doesn't spin. I wasn't aware that there was another fan so when I heard the fan running I thought I'd cracked it but it wasn't the case .
14th Feb 2020 2:42pm |
I concur about Dometic, toilets, fridge, not fit for purpose way too expensive. |
14th Feb 2020 4:35pm |
I have a week off in Devon which is suffering from floods (FFRR are made for this). I arranged for a local Dometic engineer to have a look at my A/C. He arrived about 10:00am on Monday to have a look. I switched it on and he could hear a fan running which increased in speed when instructed by the remote. This was not the fan which blew cold air into the van but another which seemed to expel air outside on the roof. As he was looking at it from inside it suddenly sprung into life. Now it all works as it should and the engineer did diddly squat! Still cost me £65 call out but you live and learn. Still only half the cost of a new pcb and I’ve spayed the whole board with Q30 waterproofing so it shouldn’t happen again. |
19th Feb 2020 9:05am |
I thought I'd run the A/C for a while to test all was ok and would you believe it runs for about 5 mins and dies.
25th Feb 2020 6:06pm |
From memory, the fresh jet is about £1200 so if you pay out £200 for parts you could sell it as a working unit for about £650-£750 which I think would be more than what you would get as a none runner? Which would help towards the cost of a new A/C
25th Feb 2020 6:54pm |
Hi Alex
25th Feb 2020 7:10pm |
The same thing I had with my fridge changed the PCB all working now out of pocket £161 against 2kfor a new fridge.
25th Feb 2020 7:14pm |
Scot told me that the likely cause of the issue was the PCB. I went ahead and had the PCB sent to a company called Electronic Partners who initially checked over the unit for anything obvious. They came back with a report stating the PCB had been wet and a few relays needed to be replaced to get everything working. They did say that without having the whole A/C system together they couldn't guarantee it would work but that everything on the PCB will be working. I paid £86 to get the repair done thinking I'd saved £200 on a replacement PCB. It arrived about 10 days later so I refitted it immediately. I switched it on and nothing other than the fan which blew externally, worked. I have no one locally willing to come to me to look at it so booked a guy (Cara-Doc) whilst I was away for the week in Devon. He duly arrived and whilst he was just looking at it, it burst into life. Hooray I thought. I then had to pay a call out charge (fair enough) of £65 but still felt quids in on the deal. A few days later I thought I'd give it a quick test and nothing.
27th Feb 2020 2:35pm |
