Home > Maintenance & Mods (L405) > key fob
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Much appreciated Stan Rolling with laughter Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #537496 15th Dec 2019 11:38am
pld118
Spurred me into action Stan, bought the replacement casing last December from Matford LR (£12.49 incl. delivery)...finally got round to it this afternoon (stuck with the original look).
Post #537536 15th Dec 2019 4:58pm
you must have little spindly fingers then Mr. Green ... - .- -.
Post #537537 15th Dec 2019 5:03pm
supershuttle
Well the key fob actually arrived today from China, I haven't opened it up yet but it certainly looks promising.
Although its actually a little bigger than this one so I might not bother.
 Geoff
Post #539321 3rd Jan 2020 7:46pm
looks like a nice fob Geoff..
i've found one on ebay but the inside looks different ..i'm hoping yours might be able to accept the insides of our fobs.. ... - .- -.
Post #539332 3rd Jan 2020 9:50pm
supershuttle
Actually I found it pretty easy, used the locating lugs to locate with the corresponding holes on the PCB and put it back together only to find a couple of buttons no longer worked (they lined up perfectly and worked before). I realised that this was due to the fact that the back of the PCB needed supporting and I did it by bending the thing that puts the pressure on the back of the battery up a bit, foam tape or similar would probably work as well, might even be better !
However although not a big as the original massive key, it's bigger than the latest one I have so I won't be using it (it does look more modern though). So into my key museum it will go Rolling with laughter
 Geoff
Post #539335 3rd Jan 2020 11:16pm
supershuttle
Although it appears to have gone up a couple of quid this is the fob I ordered.
https://www.aliexpress.com/item/4000436425...4c4d6CxX7T
Very Happy Geoff
Post #539336 3rd Jan 2020 11:23pm
i like it..if you fancy selling give us a shout geoff... ... - .- -.
Post #539376 4th Jan 2020 2:50pm
supershuttle
Stan, I'll send a PM Geoff
Post #539380 4th Jan 2020 3:44pm
