Home > Maintenance & Mods (L322) > Freeview upgrade for touchscreen TVs
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Is anyone aware of a freeview TV upgrade for FFRRs? I currently have a 56 plate Vogue SE with the touch screen TV/DVD etc, but by the end of the year the analogue TV will be non-functional in my area. I queried it at my local dealer last year and they were not aware of anything. I would have thought LandRover would have brought out an upgrade module of some sort by now. I would look for an aftermarked add-on, but that would most likely have an extra control unit, whereas I would expect LR to update the touchscreen software as part of the upgrade.
I don't watch the telly much but when I eventually sell the RR on, it would be nice to say the TV worked!
Cheers Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #5387 4th May 2009 11:49pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Guessing yours is based on the BMW system I'd say there is a solution Try NavTV or Prestige Audio in NW10
Post #5388 5th May 2009 6:15am
I'm in the same boat, surely its just a new tuner required? The newer one used in the D3, RRS and FFRR should just fit, trouble is, finding one cheap enough! Discovery 4 HSE
Post #5392 5th May 2009 8:31am
ken
Adam I am led to believe that the cables are somewhat different
Post #5393 5th May 2009 9:17am
Censored ! Discovery 4 HSE
Post #5394 5th May 2009 11:35am
nbunney
I asked my local stealer about upgrading and was told it was not possible. But not given a reason, so suggest the cable issue, as mentioned, could be the reason.
Post #5395 5th May 2009 11:35am
There's bound to be an aftermarket add-on box that can receive Freeview.
I once saw this ontop of a Range Rover in New York. This would be cool.
Looks like a satellite TV unit.
 Discovery 4 HSE
Post #5396 5th May 2009 11:40am
RRVSE
Cheers Ken. As per RRUK, I was thinking a tuner upgrade, but if that's not viable, then I was thinking that at the very worst I would be able to get a unit that sat between the existing aerial and head unit which received freeview, converted it to a UHF frequency (much like a video recorder or after market set top box) and I would tune the TV into this, the freeview channels being searched (unfortunately) via a seperate up/down scanner etc etc Steve
Post #5409 5th May 2009 2:22pm
RRVSE
I may have found an alternative if LR don't do an upgrade - an addon DVB tuner kit for £210...
http://www.parkmyauto.co.uk/ck0-1080-in-ca...-737-p.asp
Very Happy Steve
Post #5417 5th May 2009 11:34pm
ken
Looks good as I'm looking for a proper DAB solution not a highway Thumbs Up
Post #5419 6th May 2009 6:36am
Have e-mailed these guys ,sounds good, plus i noticed the night vision reverse camera , and they are only in Edinburgh 40 mins away. Thumbs Up
I take it you mean this box .
Post #5420 6th May 2009 7:32am
ken
Let us know Thumbs Up
Post #5425 6th May 2009 8:23am
RRVSE
Yep Mick, that's the box. I was thinking of using the AV inputs on the rear of the front centre armrest, but if I remember, it ony feeds the 2 rear screens, but 2 out of 3 is better than 0 !! Razz Steve
Post #5430 6th May 2009 9:21am
The Company sent me this reply ......
It is possible to do this in advance of the digital switchover. For you to retain all of the normal controls, you would require an interface connector which will provide an audio video input which will then allow you to have a digital freeview TV tuner to be integrated into your existing system.
This interface will also provide you with video in motion so that you can watch this on the move.
Installation for the tuner and interface will take around 4 hours @ £30 - £40 per hr plus VAT.
On order of the products, these will be delivered to you within 24 - 48 hours and you will be put in touch with a local installation engineer to organise an appropriate installation time and date.
I hope this is helpful?
Kindest regards
Russell (0131 555 7040)
Post #5433 6th May 2009 5:07pm
RRVSE
Thanks for that information Mick. If I order one I think I'll see if there's technical data supplied to allow me to self-install the kit, to save £120.
Cheers Steve
Post #5450 8th May 2009 7:47am
