Home > Technical (L322) > Intermittent heating |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Has anyone changed the heater temperature sensor/s?. Mine has the High line system therefore should have two, Finding one would be nice.
29th Dec 2019 2:16pm |
30th Dec 2019 2:20pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
On a long drive last night mine might be doing something similar, cabin unduly cold then fine after a restart. I noticed that the rear air vent was only ever blowing cold in any setting. Mine is a 2006 4.2 supercharged with the pre-facelift interior.
1st Jan 2020 10:21am |
Knips Member Since: 01 Oct 2011 Location: United Kingdom Posts: 70 |
Sorry a bit OT, but both my L322s had weird heating - I thought it was a 'design feature'/'they all do that' issue. |
1st Jan 2020 1:57pm |
Thanks for the replies. Already cleaned the air vent & fan working fine, as this was my first point of call. Knips, I know the L322's heating can be a little temperamental at times, but I shouldn't have these issues. I'll update once I've fitted the new sensor. |
1st Jan 2020 2:23pm |
Update:- Replaced both the temperature sensors & feels better. Cleaned the thermistor & checked that it was working by doing a resistance check.
11th Jan 2020 11:11am |
landy95 Member Since: 04 Aug 2021 Location: Hall Green, West Midlands Posts: 79 |
Hi, did you ever sort this issue out as i am having a similiar one. Went in to an indy to have a leaking thermostat fixed now its been returned and the weather getting cold i have noticed the heater is blowing cold air no matter how high i turn the temp controls up passenger and driver side.
30th Nov 2021 9:57am |
Nope:- Heater works perfectly fine until you get up to any speed. It then blows cold.
30th Nov 2021 11:58am |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 901 |
You have an air lock |
30th Nov 2021 4:11pm |
Thank you both, i was thinking its more than likely an air lock but have not had time to investigate yet. Im going to have a look this afternoon hopefully, i will keep you posted.
2nd Dec 2021 1:16pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2265 |
I had all sorts of strange heating problems years ago turned out to be the air filter housing on the bulk head as at speed it was letting air flow direct in to cabin worth a look |
3rd Dec 2021 5:38am |
Thanks Sandyt, Unfortunately already looked into this. Also tapped up all the inlets to stop any air coming in at all, but still the same.
3rd Dec 2021 5:20pm |
I recently had the same issue caused by an airlock due to a tiny coolant leak from a faulty hose clamp on my lpg vaporiser. It has driven me mad but I have finally managed to shift the air lock.
3rd Dec 2021 8:33pm |
Dave, I tend to agree. Although I have bled & bled, I think its it got to be that.
4th Dec 2021 9:58am |
