Home > My Range Rover > 2019 Servicing and repair of 2007 L322 since July Purchase.
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Well as we hit the end of 2019 I thought that I'd look back at what I have done since buying the L322 back in Summer.
Since I bought the car I have only put on 1300 miles in 5 months, most of the time it has been in the garage undergoing planned restoration.
I bought the car through an online auction site at what I consider a reasonable price of decently under 5K, understanding that I would have work to do.
I am lucky in that I have access to a family owned commercial garage and so can do stuff myself without crawling all over the floor or trying to loosen off a nut with a scaffold pole attached to a passing milk float.
And so...
RANGE ROVER Vogue and SPORT 3.6 TDV8 EGR Removal /Blanking plate...
£43.69
Oil Change + Filter ° Air Filter
RYP000061 - SCREW
SKU: RYP000061.G
Manufacturer
OEM 4 £23.48
RYH501100 - Nut for Range Rover L322 Lower and Upper Arms - For Bolts Through Arms - M14
SKU: RYH501100.G
Manufacturer
OEM 6 £6.42
RYP000071 - Bolt for Range Rover L322 Rear Lower Rose Joint on Steering Knuckle
SKU: RYP000071.G
Manufacturer
OEM 2 £4.84
RYP501160 - SCREW
SKU: RYP501160.AM
Manufacturer
Britpart 2 £14.16
RGI000012 - WASHER - FLAT - SPECIAL
SKU: RGI000012.G
Manufacturer
OEM 2 £6.26
KYF500080 - WASHER
SKU: KYF500080.LRC 2 £0.72
LR030048 - Range Rover L322 Rear Anti Roll Bar Link - For Vogue 2002-2012
SKU: LR030048 2 £17.00
RGD500180 - Range Rover L322 Stabiliser Link Bar for Lower Wishbone - For Vogue 2002-2012
SKU: RGD500180.AM
Part Type
Aftermarket Part 2 £27.86
LR023713 - Complete Lower Rear Wishbone - Right Hand - For Range Rover L322 Vogue from 2002-2012
SKU: LR023713.AM
Part Type
Aftermarket Part 1 £56.59
LR023714 - Complete Lower Rear Wishbone - Left Hand - For Range Rover L322 Vogue from 2002-2012
SKU: LR023714.AM
Part Type
TZV500010 - Transmission Sleeve for Wiring - For Range Rover L322, Sport and Discovery 3 & Discovery 4 6 Speed Boxes
SKU: TZV500010.LRC
Part Type
Genuine Part 1 £9.02
DA2142 - Automatic Transmission, Easy Change Filter Kit - For Range Rover L322, Sport and Discovery 3 & Discovery 4
SKU: DA2142.AM 1 £60.25
TF665 - Wind Deflector Kit (Set Of Four) - For Range Rover L322
SKU: TF665 1 £24.31
LR023712 - Complete Upper Rear Wishbone - Left Hand - For Range Rover L322 Vogue from 7A000001
SKU: LR023712.LRC 1 €126.55
LR023711 - Complete Upper Rear Wishbone - Right Hand - For Range Rover L322 Vogue from 7A000001
SKU: LR023711.LRC 1 €126.55
RHF000260 - Bush for Upper Rear Wishbone to Knuckle - For Range Rover L322 Vogue 2002-2012
SKU: RHF000260.AM
Part Type
Aftermarket Part 2 €12.30
RYP501150 - SCREW
SKU: RYP501150.AM
Manufacturer
Britpart 2 €16.50
SKU: RYH501100.G
Manufacturer
OEM 6 €7.26
SKU: RGI000012.G
Manufacturer
OEM 2 €7.06
RYP000081 - SCREW
SKU: RYP000081.LRC 4 €9.52
RYV000010 - Circlip for Lower Rose Bush on Rear Knuckle on Range Rover Sport 2005-2013 and Discovery 3 & 4
SKU: RYV000010.AM
Manufacturer
Britpart 2 €4.48
SPB500190 - Handbrake Cable for Electronic Park Brake - Left Hand - Range Rover L322 Vogue - 7A000001 On (SPECIAL WEB PRICE)
SKU: SPB500190 1 €76.60
SPB500180 - Handbrake Cable for Electronic Park Brake - Right Hand - Range Rover L322 Vogue - 7A000001 On
SKU: SPB500180.LRC 1 €89.22
SFS000051 - Handbrake Shoes for Range Rover L322 Vogue - Will fit from 2002-2012
SKU: SFS000051.AM
Part Type
Aftermarket Part 1 €20.97
SMK000020 - Handbrake Shoe Hold Down for Range Rover L322 Vogue - 2002-2012
SKU: SMK000020.LRC 4 €10.36
LR032644 - Bush Located in Steering Knuckle and Rear Lower Suspension Arm on Range Rover L322, Sport and Discovery 3 & 4
SKU: LR032644.AM
Part Type
Aftermarket Part 2 €15.92
LR058026 - Range Rover L322 Rear Brake Hose - Right Hand - Fits from 2006 Onward (Fits from 6A000001)
SKU: LR058026.AM
Manufacturer
Britpart 1 €11.86
LR058025 - Range Rover L322 Rear Brake Hose - Left Hand - Fits from 2006 Onward (Fits from 6A000001)
SKU: LR058025.AM
Manufacturer
Britpart 1 €12.53
RBJ500920 - Range Rover L322 Front Lower Arm - Front Suspension Arm for Vogue 2002-2012 - Fits Right Hand and Left Hand
SKU: RBJ500920.AM
Part Type
Aftermarket Part 2 €47.30
LR018343 - Range Rover L322 Front Upper Arm - Right Hand - For Front Suspension Arm for Vogue 2002-2012
SKU: LR018343.AM
Part Type
Aftermarket Part 1 €28.16
RBK500210 - Ball Joint for Front Upper Arm Range Rover L322 - For Front Suspension Arm for Vogue 2002-2012
SKU: RBK500210.AM
Part Type
Aftermarket Part 2 €10.54
LR018344 - Range Rover L322 Front Upper Arm - Left Hand - For Front Suspension Arm for Vogue 2002-2012 - Aftermarket Item
SKU: LR018344.AM
Part Type
LR030047 - Range Rover L322 Front Anti Roll Bar Link - For Vogue 2002-2012
SKU: LR030047.AM
Part Type
Aftermarket Part 2 €10.58
SKU: RYH501100.G
Manufacturer
OEM 4 €4.72
KYG000043 - Bolt for Range Rover L322 Lower and Upper Arms - Bolts Through Arms - M14 x 103
SKU: KYG000043.G
Manufacturer
OEM 4 €15.68
QYH100271 - M12 Flanged Nut for Range Rover L322 Front Anti-Roll Bar Link
SKU: QYH100271.LRC 4 €7.08
QJB500050 - Outer Steering Rack Track Rod Ball Joint for Range Rover L322 - Fits Either Left or Right Side from 2002-2012
SKU: QJB500050.AM
Manufacturer
Britpart 2 €16.42
QYH500070 - Nut for Outer Steering Rack Ball Joint - Range Rover L322 from 2002-2012
SKU: QYH500070.LRC 10 €17.90
QJB500060 - Inner Steering Rack Tie Bar for Range Rover L322 - Fits Either Left or Right Side from 2002-2012
SKU: QJB500060.AM
Manufacturer
Britpart
2 €13.82
4 Stück - 255/55 R20 PIRELLI Scorpion Verde All Season - Ganzjahresreife...
€399
09.9373.21 Disque de frein 2 40.39 80.78
P 06 044 Kit de plaquettes de frein 1 34.62 34.62
Range Rover L322 Ecrou de roue inox X20-RRD500290 46.90
7L ZF-Lifeguard 6 6HP S671.090.255 (7 bottles) €124.80
Instant Shudder Fix 2x Lubeguard 19610 15.78
All Copper brake lines + Fluid replaced
Chassis Painted 3 coats Smoothrite Black
Interior Leather Woolite detailed and Black polish sealed
4 Wheel Laser Alignment twice
4 Wheel tyre balancing
ZF Gear Box Oil change applied (27/12/2019)
Side Bars fitted (recycled Fanders/RRUK)
Autel Maxi AP200 OBDII Bluetooth added for onboard Android tablet. €71.99
Next job,
A mighty good clean! Rolling Eyes
Best Rich
Post #538742 28th Dec 2019 8:25pm
Swipe
United Kingdom 2004 Range Rover Autobiography Td6 Java Black
Funny enough I keep a record of everything that I have done to my Td6 on my phone is: what was replaced, cost, mileage and the date.
Sometimes makes for some scary reading about how much has been spent in the year 1/2 that i’ve had the car.
Showed my list to my manager who just got a RR SPORT 3.6 and he was quite shocked about the spending, have warned him to be ready to fix things himself or be prepared to pay for a garage to repairs things.
RR are nice but they do eat at your wallet 😂. 2004 Autobiography TD6 Java Black
Post #538768 29th Dec 2019 7:32am
RichM63
Regards costs, I mentally don't count things like general maintenance, ie engine oil, filters, tyres etc. This is the same for all cars.
I also used new nuts, bolts, and washers for every component, I'm happy, but a saving could be made (albeit false IMHO).
I reckon that in Parts, then I'm about where I expected to be.
Labour does not bear thinking about!!!!! Rolling Eyes
Rich
Post #538857 29th Dec 2019 8:56pm
Sandyt
I spend about 3k a year on maintenance and servicing most preventative and it has been a great car now done over 185k
Post #539270 3rd Jan 2020 5:37am
roblane65
I too can be quite sad at times ,I do keep a record of all works carried out date cost and mileage I think it adds a bit come sale time and shows its been cared for. but bolts nuts and washers only get replaced if theirs a problem with them. Wink Range rover 4.2 SC 06MY.
Post #539541 5th Jan 2020 7:48pm
RichM63
Well so far in 2020.
New 020 110ah 920A battery mid January.
New bonnet rams last week, (with the old ones it was a bit like ducking the guillotine).
Replaced all grills, side, bonnet vent, and rad front grill with Stornoway colour coded painted supplied courtesy Fanders.
Replaced unused 19" spare wheel with correct size 20" spare, idem Fanders.
Today replaced the Air Suspension Reservoir with a genuine new LR tank, the old one was just about ready to leak.
Easy job, batt disconnect, loosen under shields etc, loosen air line, wait for decompression, remove air line, remove old tank.
Reverse procedure with new tank.
Start car and do reset thing with steering wheel.
Job done.
FWIW, due to the horrible condition of the surface of the old tank, even though I was using a brand new LR tank, over the past 2 weeks I gave the new tank 5 coats of black gloss anti-rust metal paint. (smoothrite yada yada).
Rich L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #544345 18th Feb 2020 7:47pm
