Home > Technical (L322) > battery drain |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2652 |
Search for final stage resistor, first thing to change, very common. |
27th Dec 2019 6:07pm |
sibelius Member Since: 19 Aug 2018 Location: worcestershire Posts: 19 |
Really? Oh well thats the first reply Ive had and hopefully the only one I will need! Would I expect to hear the fan running if its faulty even with ignition off or can the fsr drain battery without obviously doing anything?
27th Dec 2019 6:32pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
I note you were unable to charge the battery when it was connected to the car.
27th Dec 2019 7:57pm |
OK, well its a big drain, new battery flat overnight! I'm going to get a mobile electrics guy to check it out after the holidays, as it sounds way beyond my capablities. If he can't trace it then there is an indepedent LR place nearby, maybe they will sort it for me. Certainly don't want the main dealer to get their hands on it, could need a second mortgage!! Thanks for your input |
27th Dec 2019 8:17pm |
