Home > Technical (L322) > Mice and alternator issues - interesting symptoms. Resolved. |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Look for the signs of nesting. Look everywhere as they get everywhere. Then start checking your fuses. Good luck. |
27th Dec 2019 11:48am |
Jri711 Member Since: 26 Feb 2019 Location: Norfolk Posts: 20 |
Look very hard, I had the same problem a few tears ago, gearbox went into fail safe & was told said box needed a rebuild being & early 322 I just sold the car to a friend for spares/repair he investigated a little deeper, found mice had eaten the loom for the gearbox ecu !! Second hand ecu & a loom repair and she’s still going now. Yes I was little sick. |
27th Dec 2019 1:21pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Mice love the looms next to the front suspension turrets... Had a few in with issues! All been eaten there... |
27th Dec 2019 5:59pm |
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 |
Would that be under the wings and behind the plastic wheel arch liners? |
27th Dec 2019 6:31pm |
No, very obvious with the bonnet up sir...
27th Dec 2019 6:59pm |
Ah, thankyou! Will have a proper look tomorrow! |
27th Dec 2019 7:06pm |
Ok, so, no Mice damage anywhere that I can see. But the beginnings of a nest in the 'V'. They have probably been put off by me using the car the last few days...mouse traps in the engine bay the last two nights but no takers yet..
28th Dec 2019 4:17pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
You said you have only started to use it for a couple of days, I would Check your battery voltage at rest and charging -plus under load. A battery in poor condition with give all sorts of weird issues. |
29th Dec 2019 8:20am |
So, I checked the battery and all seemed well. The following day I drive 40 miles without a single fault showing. Today I took it to Famous Four Louth and within 5 minutes of setting off she was lit up like a Christmas tree...absolutely everything going bananas...even the speedo was intermittently dropping to zero! But the car itself still performed faultlessly apart from a shaky tickover!
3rd Jan 2020 12:09am |
