Home > Technical (L322) > Disconnect battery before removing top dash panel?
Madlotus
Hi all,
I’m about to attempt replacing the heater fan on my 2009 l332, I’ve heard all sorts of horror story’s of failed electronics when reconnecting the battery, what is the consensus? Those that have changed their fan, did you disconnect or leave connected but avoid the airbags? Thanks Ian
Post #538307 23rd Dec 2019 3:56pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
Personally I'd rather disconnect the battery and then muck about with electrical components and deal with reconnection afterwards.
The Battery was designed to be disconnected.
Currently mine is disconnected as is undergoing charging.
Best Rich
Post #538336 23rd Dec 2019 7:43pm
Shouldn't be any problems with disconnecting the battery, usually doing so can improve things if anything.
Post #538338 23rd Dec 2019 7:47pm
Madlotus
Thanks guys, I’ll play it safe and disconnect. Cheers
Post #538347 23rd Dec 2019 8:44pm
