Home > Technical (L322) > Smoke from engine when switched off
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Just wondering if anyone might be able to shed some light on an issue I’m having with my 3.6TDV8, please.
When I stop the engine after a spirited drive, there is smoke coming from the passenger side of the engine.
Only seems to happen after the engine is loaded up, for example after a long hill climb.
I don’t think it’s exhaust, as the engine is off and the smoke is still there.
Also, I’m pretty sure it’s not the fuel burning heater as it’s summer down here 😀
(The vehicle is a Sport, but I didn’t get much feedback on the sport forum) 2007 3.6 TDV8
Post #538173 22nd Dec 2019 6:21am
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
What's the smell like?
I recently had a fuel leak from and injector fuel supply pipe. Fuel was leaking down on to the exhaust manifold and smoking. It must have been doing it all the time but I only noticed it when I stopped.
Presume you have no error messages?
Post #538180 22nd Dec 2019 8:59am
cheezels
I’ll have to have a good sniff 😀
The smoke is a sorta beige colour. Bit like wood smoke.
Seems to be coming predominantly from the rear of the engine (towards the firewall).
How difficult was it to find the fuel leak? 2007 3.6 TDV8
Post #538193 22nd Dec 2019 10:36am
nino_nino
after you stop take fresh air box (pollen filter) out, use mirror to take good look around back of the engine. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #538195 22nd Dec 2019 11:04am
cheezels
Sorry. Should’ve mentioned it’s a Sport (so can’t remove pollen filter plenum) 2007 3.6 TDV8
Post #538196 22nd Dec 2019 11:08am
