I fitted LEDs to my main beams a couple of months ago, my car had filament lamps in the main beam and factory Xenons in the dip.
Recently with some evening driving, winter drawing in etc, I fnoticed that the offside beam was too high. I'd tried to adjust it, but it wouldn't go down low enough it went down a bit then there was a click and it popped back up.
So with some free time today at Christmas I decided to work out what was going on. I removed the headlamp completely so I could see inside from the back.
The new main beam LEDs are the type with a heatsink and fan on the back, and I could see that the bottom edge of the heatsink was fouling on part of the headlamp casing and was using the whole frame (which carries dip and main beam) up.
So the problem was my fault - I hadn't connected the beam height problem with the installation of the LEDs!
So I took the LED out and filed about 2mm off the bottom corner of the heatsink, re-installed and it now clears the case, just.
The beam adjuster now works just fine, so I'll realign the light later when it gets dark.
Job's a good 'un.
A
2011 Vogue 4.4 Diesel.
