![]() | Home > Off Topic > Network / wifi |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
Wireless repeaters are generally not very reliable. Is there any way you can get a cable a bit closer to the problem room than the current access point?
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 ![]() ![]() |
Connect your two routers over you power cables.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
+1 to using mains power cable to carry network traffic.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Thx guys
The one I have may not be around anymore, but I plug one part into the wall socket and connect an rj45 ethernet cable to it from the router and in the garage have another unit plugged into the wall giving a WiFi signal to the garage and outdoors.
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 354 ![]() ![]() ![]() |
I've previously used the Netgear equivalents of that BT Wireless Extender in multiple houses to successfully extend coverage where it was patchy before. Not quite as good as a proper wired extension or using the mains power cables, but they worked well enough for us.
Another option to consider is mesh WiFi which is designed to use a back channel to extend the WiFi range.
Thanks all.
I'll be interested to know how you get on. The speeds quoted on the box for those AV line adapters are laughable. Best case I was getting about 20Mbps. My fibre modem is on a spur though which probably has a detrimental effect. 2016 Skoda Octavia VRS Estate
I recommended devolo powerline kit for a reason... use TP-link if you want to compromise reliability for price. Not worth it in my experience.
If you want powerline with WiFi (I.e. not use your old BT Hub 3), then this is the devolo equivalent to what you pasted above:
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2666 ![]() ![]() |
Have the devolo kit, works very well, use it for sky box & ps4, way better than WiFi |
ok thx chaps.
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Hi Greg,
