![]() | Home > Maintenance & Mods (L405) > Adaptive dynamics re-calibration |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Switching off DSC makes the shocks firmer so you might like to do a test to see if there is any improvement.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
have you checked the tyre pressures, maybe lower them? ... - .- -.
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 ![]() ![]() ![]() |
That was the first thing done Stan 31psi in front and 34 psi in back and has made no difference |
Will try that today and have a look through the menu on my gap tool ![]() Will get in touch with pat at gap if nothing showing Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!! ![]() |
some good info here,
Switched the DSC off today and has had a significent improvement in the ride quality Ive travelled approx 50 miles today over the same roads I do normally The car now absorbs the potholes and bad road surfaces a lot better The biggest improvment ive noticed is the steering ! I was constantly correcting the steering beforehand which seemed to pull slightly to the left when hitting rutts in the road and pothole etc and is near enough perfect now For some reason the throttle response is also a lot smoother (placebo effect maybe) So obviously there is a problem with the DSC and all pointing to the link below that stan kindly supplied to me ![]() https://www.fullfatrr.com/forum/topic47445...e+dynamics Range Rover L405 Suspension Fault. Vehicle range 2013-2017. TB issued 27.July 2018. LTB00557V10 VIN 000001-380216 The hard part is now going to be convincing the dealer that there is a problem as ive reported an issue with the suspension twice now and head technician seems to think its ok ![]() ![]() ![]() |
DSC won't be the cause, only that the CVD module is programmed to stiffen the shocks while DSC is off, presumably so that the vehicle would be more controllable by the driver in the event of sudden swerving. With the improvement that you have experienced and in the absence of the knocking caused by the valve block referred to in the linked thread, I expect that the shocks are not functioning properly, possibly due to their seals worn.
