![]() | Home > Technical (L322) > L322 suspension fault - towbar module? |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Module is in the boot, rear right cubby as you look forward into the car, open the cubby and look towards the rear of the space, you should see a grey module tucked up in the corner -- disconnect it and see if it cures the issue, disconnection should have no other effect (other than disconnecting the towbar electrics) Current: 2011 FFRR Vogue SE 4.4 TDV8
JonnyO Member Since: 01 Sep 2019 Location: Loughborough Posts: 28 ![]() ![]() ![]() |
Can’t see the module. Any further help as to how I find the damn thing? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
What tow bar do you have, is it OE or aftermarket?
Take a photo of the rear right cubby and post it Current: 2011 FFRR Vogue SE 4.4 TDV8
Never did get to the bottom of this as it was an aftermarket tower with a rats nest of cabling |
