Tailgate not opening on switch, but opens using GAPIID | |
Hi All,
First techie post on here, I have doen a search but none of the results show a similar problem that I can find.
I have had the 2011 TDV8 for about 2 months and loving it, I have noticed the lower tailgate has stopped working on the button, it was intermittent for a while, but now seems to be completely dead on the tailgate switch.
I pulled the switch and linked the connector out on the plug and it still will not work. Switch bells out as working on the DVM. Fuse looks good and I have swapped the relay for a twin on the board and still nothing.
However, when I use the IID to open the tailgate it works OK.
It seems that the voltage at the switch was only 7 volts. But I need to verify this again.
Are there any connections I need to check in the loom?, known places that it breaks down? Other fail safes that could cause the issue?
Thanks in advance.
Neil
