Home > Maintenance & Mods (L322) > Preventative maintenance for air suspension?
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
Seem to be quite a few problems that come about with the systems, no doubt as they get old. Is there any form of maintenance that you can do to help keep things in good order? Even things that aren’t maintenance, like taking it to full
height every now and then? Changing heights often? I regularly use the access height drop, am I wearing it out or keeping it working? Mine seems to be working perfectly now and has 114k on the clock (frantically touches wood!) Id just like to keep it that way
Any tips?
Post #536631 7th Dec 2019 10:15am
Clivefog
Change ride height regularly was the advice I got.
Also on full height have a spray of soapy water around the base of the front air bags, any bubbles shows impending doom, none give peace of mind.
Other than that get out and enjoy it.
Post #536633 7th Dec 2019 10:32am
DrRob
I use access everyday and off road for regular underbody inspections Rolling Eyes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #536634 7th Dec 2019 10:36am
rjff
As above, operate in all modes regularly.
There's an air filter and a drier for the compressor. Info in the routines in the WM. Cheers
Richard
Gap IIDBT
Post #536637 7th Dec 2019 10:54am
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Also clean around the Base of the air bags. Sand and dirt can accumulate there, so if you jack the car up give them a good clean. That's generally what wears holes in them. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #536667 7th Dec 2019 5:17pm
^ I clean these as routine/part of our service regime... It goes like concrete so must be abrasive long term Thumbs Up
Post #536694 7th Dec 2019 11:47pm
